Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 12-03-2019, 07:47 PM
romainchu78 romainchu78 is offline
Private
Member's Gallery
Default CP4 High pressure pump disaster prevention kit
hello, what is the best quality/price prevention disaster kit on the market for a 2012 f250 6.7L ?
  #2
Old 12-03-2019, 07:52 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
Whatever floats your boat. Not really a necessary item imo
Just be careful what you put in the tank.
  #3
Old 12-03-2019, 08:08 PM
ncollins64's Avatar
ncollins64 ncollins64 is offline
Colonel
Member's Gallery
Default
The s&s kit is very nice and well made. I’ve installed several. As Sootie said use good fuel and change filters with motorcraft every time.
__________________
•2013 F350 CCSB PLATINUM
•08 F-350 CCSB 950/1493
Midwest Diesel, Elite Diesel, RCD, OUO, No Limit Fab, PMF Fab
•1997 F-350 7.3, srw, rclb, 4wd, 5speed (work truck)
•Past rig: 2000 F-350 ccsb, 1100 hp 6.7 cummins
  #4
Old 12-03-2019, 08:19 PM
Private
Member's Gallery
Default
how many hours did you spent installing it?
are there any cheaper choices than S&S (bit still good quality)?
I buy my diesel fuel from a high traffic Valero gas station. plus i use fuel additive. plus i change my fuel filters twice a year. plus i drain water from tank fuel filter once a month. plus i have a very conservative driving (never any brutal accelerations, try not to exceed 1,500 RPM, do little warm up before driving) but was told the CP4 might still break. my truck has 140,000 miles. i bought it when it had 106,000 miles and i don't know if previous owners took care of it or not. i just can't afford $10,000 in repair for changing the complete fuel system if this happens to break. I would feel more comfortable doing it.
  #5
Old 12-04-2019, 05:19 AM
sootie's Avatar
General
Member's Gallery
Default
Wow you're paranoid.
  #6
Old 12-04-2019, 05:59 AM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
Major
Member's Gallery
Default
I'd suggest you sell your truck to a real man.....he deserves it more than you.
  #7
Old 12-04-2019, 06:30 AM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
It’s good to try to take care of stuff, but with that driving style you’re doing more harm to the emissions system than you are good to the rest of the truck.
  #8
Old 12-04-2019, 08:31 AM
Petro's Avatar
Petro Petro is offline
Major
Member's Gallery
Default
Its a 6.7l V8, not a C15 Cat, some rpm is definitely not going to hurt it and some hard accelation every so often is a good thing. You're not saving anything by driving it the way you are. If you're that worried, I'd suggest buying a gas engine.
__________________
08 F250 CCSB 4x4 6.4 5r110 140k - Tunes, Diet, etc
94.5 F350 CCLB Dually 4x4 7.3 PSD ZF5, 370k - 180/30's, Tunes, etc
06 F350 CCSB 4x4 6.Blow ZF6, 220k - Injectors, Turbo, Fass, currently in pieces
Pulling Truck
05 F250 CCSB 4x4 6.Blow 5r110, 230k - Hybrid 250/100's, S369, RR, Fass
  #9
Old 12-04-2019, 11:38 AM
Private
Member's Gallery
Default
Quote:
Could you please explain that more in details?
  #10
Old 12-04-2019, 12:49 PM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
Idling, low rpm driving, etc keep heat much lower in the combustion and exhaust level which increases soot loading.
Soot loading contributes to more frequent regens, lower fuel mileage, and shorter emissions equipment life span.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
