Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #21
Old 12-11-2019, 01:15 PM
CTC DEEZUL's Avatar
CTC DEEZUL CTC DEEZUL is offline
General
Member's Gallery
Default
Yea but still your pump will fail eventually. If it's sending metal out, it's done. So even after filters catch what's thrown back into tank via the bypass, you've only got a few hundred miles if that before pump grenades.
I'm trying to sell cp3 conversion kits(for DMAX) and FASS systems to customers with good running trucks. That's $5k spent there is alot better than the $11k they'll spend after the pump fails and contaminates the system
__________________
Teamsters Local 444- Rolling Coal United
  #22
Old 12-11-2019, 01:33 PM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
Major
Member's Gallery
Default
Yea. I found the newer S&S video that gave some internal understanding to the "how it works" of the HPFP. I gathered the biggest point was not that the roller bearing of itself causes the problem, but a two fold event that requires the guide to turn 90* to the cam which causes the roller bearing to now be in a "not as designed" orientation. That is when the most severe HPFP failure issue can occur and happen where the bearing is eaten up by the cam.
I want to say the video gives credence to the air that becomes entrapped in fuel as the possible/principle source of creating the environment to cause the guide to rotate 90*.
I'm not trying to say one way or the other how these failures happen. Just giving info that I gathered from the video.
So with the combined factors of air entrapment and poor fuel lubricity these are key elements of the HPFP failures plaguing the industry. Yes, one can cause the issue just as much as the other, but both issues combined cause a huge issue to rise up much faster.
Does that sound about right?
I would never disagree adding filters, additional water removal, supporting pumps, and air removal are quite effective "insurance" to helping our fuel systems.
  #23
Old 12-12-2019, 10:49 AM
treatcg treatcg is offline
Private
Member's Gallery
Default
Could always upgrade to the Exergy improves stock CP4 pump or Exergy inlet metering valve depends what you want to spend.
__________________
Clayton
2016 F250 Lariat FX4 6.7
  #24
Old 02-24-2020, 01:20 PM
Bigdogdiesel Bigdogdiesel is offline
Private
Member's Gallery
Default
I have a 2011 with 160k and a 2014 with 170k. I have been adding Wal-Mart 2 stroke oil in 85% of my fill ups since new. (Actually starting at 40k on the 11). 1/2 gallon on the 32 gallon tank (14) and 1/3 gallon on the 11 with the small tank 23 gallon or so. No fuel system or *** issues as of yet!
  #25
Old 02-24-2020, 01:36 PM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Cool. But that doesn't help with air or starvation if your lift pump was to go out.
__________________
  #26
Old 02-24-2020, 09:47 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
From a beloved cp4 today on a Duramelt with 175k. Guy said he got a fuel filter warning, then it just shut down on him. He said he drained some water out of the filter afterwards, and then replaced the filter. Lol.
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2018 Ram 5500 Mechanics Truck
2001Tdi Jetta 5 speed
  #27
Old 02-25-2020, 06:36 AM
blacksmoke.r.us's Avatar
blacksmoke.r.us blacksmoke.r.us is offline
Sergeant
Member's Gallery
Default
Just drive it... I've seen where some people take exceptional care of a vehicle and it has many issues. Then I've seen a rancher who doesn't change oil for years much less fuel filters and it never stops running.
Yes preventative maintenance will help in most cases but in some instances things just fail, no matter how well they're taken care of. Take your chances and do what you feel is right.
IMO like most have already said put good fuel, drain water and drive it. Or you could always go buy a new one with a warranty.
  #28
Old 02-25-2020, 07:47 AM
CTC DEEZUL's Avatar
General
Member's Gallery
Default
Quote:
Oh man I love seeing that. Money in the bank!
__________________
  #29
Old 02-25-2020, 11:34 AM
Connor M's Avatar
Connor M Connor M is offline
Lieutenant
Member's Gallery
Default
Two stroke oil in a cr lol
__________________
2008 CCSB 6.4 Harley Davidson- PPEI Tuned, EZ Lynk, 4" Jamo Stainless Exhaust, Down But Not Out
2008 CCLB 6.4 Lariat Land Yacht- H&S tuned
2008 EC C&C F450 6.4 Work Truck- Almost there
2003 RCLB 6.0 XLT- 260,000 miles, no name tunes, stock as can be
6.0 Dump Trucks- 350 and 450
VT365 Rollback
  #30
Old 02-27-2020, 07:28 PM
ghohouston's Avatar
Colonel
Member's Gallery
Default
Quote:
Not quite. I work for a heavy equipment dealer as a field mechanic. This is a customer of ours and I was asked to go diagnose when they broke down on the highway. They towed it to a local G.M. dealer.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
