Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 03-31-2020, 04:22 PM
farm boy's Avatar
farm boy farm boy is offline
Sergeant
Member's Gallery
Default Any Experience w/ 6.7 Aftermarket Exhaust Brakes?
I have a 13' with a 17' turbo setup and would like to add on some type of exhaust brake.
Does anyone have any experience with the electronic modules that plug into the trucks wiring harness and use the factory turbo veins like the BD turbo or AFE kits?
https://afepower.com/afe-power-77-63...c#applications
https://shop.fullforcediesel.com/bd-...-brake-2001102
Or with an actual Exhaust Brake setup that mounts into the exhaust that's air operated like we used on the 7.3's? Would it work with a VGT style turbo?
https://cppdiesel.com/bd-diesel-1028...rsal-5-0-inch/
Thanks
__________________
~2013 F-350 6.7L Dually 4X4 {17 Turbo & HPFP, NL Piping Kit, 5" exh & Proven Diesel Tunes}
~2002 F-250 7.3L 4X4 Flatbed
~2014 Toyota Tacoma 4X4
~2004 F-350 Shorty 6.0 (SOLD)
  #2
Old 03-31-2020, 07:27 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
Did the 13's not incorporate the vgt for exhaust braking?
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2018 Ram 5500 Mechanics Truck
2001Tdi Jetta 5 speed
  #3
Old 03-31-2020, 11:03 PM
Swaan's Avatar
Swaan Swaan is offline
Lieutenant
Member's Gallery
Default
13s did not have vgt turbo.
I'd say get a custom tune to utilize that function.
The factory exhaust brake works really really good. You don't need to add one.
__________________
E97 f250 ECLB. SOLD!
Dana 60 front with rsk kit. 5" blocks in rear. 4:10 on 35s. Blackwater reman 7.3 with arp studs , comp springs. 175/80 pis inj, adrenalin hpop,irate fuel system with fuel lab pump. Borg warner 364.5 fmw with 1.00 a/r housing. EC450 horton electric fan clutch. ZF5 shaker.
--16 f350 ccsb lariat 6.7 tuned and D-leted!!😈
--15 VW passatt TDI sport. Tuned and D leted 6 speed
  #4
Old 04-01-2020, 05:49 AM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
Major
Member's Gallery
Default
When working correctly the OEM process using the VGT and trans shifting works great. It's not going to be a Jake Brake but it's going to work.
  #5
Old 04-01-2020, 09:02 AM
Black AOD's Avatar
Black AOD Black AOD is offline
Colonel
Member's Gallery
Default
All 6.7's 2011-current have VGT turbos. However the exhaust brake function was not introduced until the GT37 turbo was introduced and updated in 2015.
__________________
08' F350 6.4L EC/LB FX4 - long gone.
2017 F350 CCLB 6.7 SRW Platinum - No Limit, Warren Diesel, Exergy, FASS Fuel Systems, Taterbilt Turbos, OUO, KING Racing, PMF
  #6
Old 04-01-2020, 09:22 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
in can be done on pre 15 trucks with tuning. Nothing to write home about though...
  #7
Old 04-01-2020, 01:06 PM
farm boy's Avatar
Sergeant
Member's Gallery
Default
Quote:
No, that option came in 15+. 11-14 only has trans downshifting in Tow/Haul mode
Quote:
I rode in my neighbors 16' while pulling his stock trailer and the difference in his exhaust brake and trans down shifting was awesome compared to just my trans downshifting.
What other options do I have besides getting a newer truck? (Not gonna happen)
Who can/will write me some updated tunes for a d3leted truck? PM me if needed
__________________
  #8
Old 04-01-2020, 11:10 PM
ghohouston's Avatar
Colonel
Member's Gallery
Default
I see. Thinking back, I do remember when my old boss got a 15 model, being surprised to see the exhaust brake. And I'm pretty sure all big 3 diesel pickups have had vgt's for at least the past 12 years
__________________
  #9
Old 04-02-2020, 03:13 PM
Swaan's Avatar
Lieutenant
Member's Gallery
Default
My bad, I thought the 11-14 trucks only had wastegate turbos . I stand corrected. They are all vgt.
Should be able to activate or utilize that brake function through tuning like others have said.
__________________
  #10
Old 04-03-2020, 06:57 AM
sootie's Avatar
General
Member's Gallery
Default
Yes, all 6.7 turbos are vgt however; the 11-14 turbos cannot handle the shock of exhaust brake tuning. What the OP is referencing is 15+ style vgt on 11-14 model truck. THAT is doable with tuning.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
