Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 05-25-2020, 06:25 PM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
Major
Member's Gallery
Default BD Exhaust manifold kits
Has anyone tried the BD kit?? Seems like it may help on airflow to the turbo. For all the work that people do for a turbo swap it seems like adding a tad more $$$ change into the mix could add some decent results.
  #2
Old 05-25-2020, 06:43 PM
jcain jcain is offline
Major
Member's Gallery
Default
What turbo
__________________
2016 F350 CC-DRW Fx4, Tow Boss, Monochromatic King Ranch
Ezlynk 2, Fox 2.0 resis, Pmf Fox 2.0 DSS, OUO ALA, OUO spring thing, OUO traction blocks & bars, AL 5000 ultimate + wireless one, AMP steps, Retrofitted Projectors, Midwest comp 3r trans with Precision converter, HhS triple turbo kit with PTE 6870s, H&S dual fuelers with RCD 100% injectors,
  #3
Old 05-25-2020, 07:10 PM
Major
Member's Gallery
Default
I'd use a stock or modded stock VGT myself. I wasn't sure if anyone went down this road with a customer or for their own truck.
  #4
Old 05-26-2020, 12:41 AM
Erikclaw's Avatar
Erikclaw Erikclaw is offline
Colonel
Member's Gallery
Default
They don't make them for the 2016 i believe. Actually they make one for one side and not the other. The machine shop was looking then up and that's what they found... I was also told they don't make much difference.
__________________
2012 DPC Champion
SDRCM #125
88mm Precision with a 62vgt
125% injectors major motor mods
  #5
Old 05-26-2020, 04:30 AM
Major
Member's Gallery
Default
BD just released the 2015+ kits.
  #6
Old 05-26-2020, 07:34 AM
Black AOD's Avatar
Black AOD Black AOD is offline
Colonel
Member's Gallery
Default
Quote:
well hot damn, hes right, they did.
https://us.bddiesel.com/products/6-7...31452435382341
__________________
08' F350 6.4L EC/LB FX4 - long gone.
2017 F350 CCLB 6.7 SRW Platinum - No Limit, Warren Diesel, Exergy, FASS Fuel Systems, Taterbilt Turbos, OUO, KING Racing, PMF
  #7
Old 05-26-2020, 08:09 AM
Major
Member's Gallery
Default
While the 11-14 kits have been out, I haven't seen any reports of shops/people installing them. As anything with a motor increased airflow or the "smoothing" of airflow tends to help a motor.
I figured there had to be someone who dropped the 11-14 kit it with a build or when they swapped around turbos.
I've been quote happy with my 2015, just thinking of giving the OE turbo a mild mod/rebuilt figured with all that stuff off.....why not go a little deeper.
  #8
Old 05-26-2020, 08:15 AM
Black AOD's Avatar
Colonel
Member's Gallery
Default
Everything exists now to do top to bottom on 6.7 motors if you choose to rebuild....
Numerous piston options, Wagler and Carrillo rod options, D&J now has a rod option with 35mm wrist pins.
Numerous head stud and main stud options, numerous valvetrain options. Several Billet cam options.
MPD makes billet girdles and main caps.
Odawgs has the ported intake manifolds and now BD has drop in exhaust manifolds.
Numerous single turbo options, compound kits, H&S has triple kits....
Modified body injectors up to 300% now exist....
So many other brands and parts that would take too long to list in here....
the 6.7 aftermarket world really has opened up a lot now.
__________________
  #9
Old 05-26-2020, 09:33 AM
Erikclaw's Avatar
Colonel
Member's Gallery
Default
Carrillo is about to start testing a new forged piston for street trucks. Different alloy so it takes heat cycles better. I think I know I getting the first set ever....Lead Foot Diesel has been using these manifolds a lot.
__________________
2012 DPC Champion
SDRCM #125
  #10
Old 05-26-2020, 09:43 AM
Black AOD's Avatar
Colonel
Member's Gallery
Default
Quote:
I heard about that. That should be interesting.
The 2020 motors have steel pistons now too. And they utilize a 1/2" longer connecting rod since the wrist pin eye was moved on the piston. So I wonder if anyone will make the 2020 rod in the aftermarket so you could run a 2020 steel piston? That would be interesting to see.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
