Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #291
Old 03-28-2020, 05:38 PM
jcain jcain is offline
Major
Member's Gallery
Default
Drug the ole wagon across the grapevine in California today. If anyone knows that pass, it's a brutal sob headed southbound.
Drop the wagon off in Long Beach and set up. Then cruised the PCH and nabbed me an srt8 challger and a 13/14 Shelby gt500 on race gas.
All on the same tune of 1000us fuel.
__________________
2016 F350 CC-DRW Fx4, Tow Boss, Monochromatic King Ranch
Ezlynk 2, Fox 2.0 resis, Pmf Fox 2.0 DSS, OUO ALA, OUO spring thing, OUO traction blocks & bars, AL 5000 ultimate + wireless one, AMP steps, Retrofitted Projectors, Midwest comp 3r trans with Precision converter, HhS triple turbo kit with PTE 6870s, H&S dual fuelers with RCD 100% injectors,
  #292
Old 03-28-2020, 09:02 PM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
I’ve been up and down the Grapevine. It’s mean.
Sounds like you’ve got it dialed in!
  #293
Old 05-25-2020, 06:45 PM
Major
Member's Gallery
Default
Still a brute.
__________________
  #294
Old 05-26-2020, 07:40 AM
Black AOD's Avatar
Black AOD Black AOD is offline
Colonel
Member's Gallery
Default
Hows the trans holding up in this thing?
__________________
08' F350 6.4L EC/LB FX4 - long gone.
2017 F350 CCLB 6.7 SRW Platinum - No Limit, Warren Diesel, Exergy, FASS Fuel Systems, Taterbilt Turbos, OUO, KING Racing, PMF
  #295
Old 05-26-2020, 09:08 AM
Major
Member's Gallery
Default
0 issues. Hot fuel is my biggest enemy, nothing else so far.
__________________
  #296
Old 05-26-2020, 09:37 AM
Black AOD's Avatar
Colonel
Member's Gallery
Default
Yeah I remember Pete and Cody both fought hot fuel issues when they had their built motor, bigger turbo 6.7s. They both ended up doing additional fuel cooler fans mounted in the bed.
Whats your low pressure fueling setup, is it 2 independent pumps to feed the CP3 and CP4 or is it a y bridge pump setup?
__________________
  #297
Old 05-26-2020, 09:53 AM
Erikclaw's Avatar
Erikclaw Erikclaw is offline
Colonel
Member's Gallery
Default
https://youtu.be/CTD8iiWd6W4
Super boring, but everyone always asked how it drove. Videos don't lie. This is on my 750+rwhp tune. I jump on it pretty good around the 5:30 mark. It'll lay black 11s down from a 50+ roll no problems.
The vgt+atmo combo was so responsive.
Nothing better than the sound of Precision's.
__________________
2012 DPC Champion
SDRCM #125
88mm Precision with a 62vgt
125% injectors major motor mods
  #298
Old 05-26-2020, 10:43 AM
Major
Member's Gallery
Default
Fass signature 125 to the cp4 and fass 95 to the cp3. The stroker cp4 and stroker cp3 are the hot fuel culprits if I had to bet. Tons of pump on tap and just not using it on the daily cruising. Hot fuel cycle.
__________________
  #299
Old 05-26-2020, 10:44 AM
Major
Member's Gallery
Default
Quote:
Sadly, lost the signature precision compressor scream going to the 6870s.
__________________
  #300
Old 05-26-2020, 11:45 AM
Black AOD's Avatar
Colonel
Member's Gallery
Default
Really? Thats odd
Sent from my SM-N975U using Tapatalk
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
