Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 07-29-2020, 11:57 AM
Petes6.7 Petes6.7 is offline
Private
Member's Gallery
Default 6.7 lift question
On my 2016 F250 I have a Readylift 2.5" front kit (with the track rod bracket). Its actually only 2.25" it turns out. With my PMF 4" blocks and airbags in the rear, I find that having about 10psi in the bags makes the truck ride nice, but gives me quite a bit more rear rake than I wanted. I like the height in the rear, but want a little more in the front.
So, thinking about getting a set of PMF 2.5" front spacers, with some 1/4" spacers to fine tune it to maybe 3" total.
My question is this. At what point do I need to consider radius arm drop brackets? Right now, I have 2 degree caster bushings that I installed with the Readylift and the truck drives great.
I'm new here, I appreciate the help.
-Peter
  #2
Old 07-29-2020, 12:22 PM
erbear28 erbear28 is offline
Private
Member's Gallery
Default
Id look into the ouo drop brackets that also help correct the castor. Even a 2.5 level will benefit
  #3
Old 07-29-2020, 02:58 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
any lift over stock requires a caster adjustment. Either drop brackets or ball joint alignment cams.
  #4
Old 07-29-2020, 04:27 PM
Private
Member's Gallery
Default
Quote:
Those are nice. I like that they move the axle forward a smidge. I could probably put those on, and maybe go back to the stock caster bushings and be OK with a 2.75 - 3" lift in the front.
thanks!
__________________
Peter
2016 F250 CCSB Lariat 6.7
  #5
Old 07-29-2020, 07:41 PM
Private
Member's Gallery
Default
Quote:
thanks!
If I remember correctly, the ouo brackets can be used in conjunction with the castor shims which over 2.5 Id leave the adjusters in
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
