Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #1
Old 10-30-2020, 11:04 AM
tyler2k tyler2k is offline
Sergeant
Member's Gallery
Default weird ipr issue
so iv got a 03 6.0, with in the last 30k iv done injectors, hpop and cooler. my ipr at warm is always 25% and my icp is between 630 and 640. iv noticed when I get close to 3k miles on my oil I'll be sitting at a light and the ipr will go up to 27 to 29 and the truck will sound different. icp tends to stay the same maybe once in awhile getting to 650 for a second. but when I put fresh oil in it the problem goes away. any ideas
__________________
97 eclb powerstroke, 3in down pipe to 4in diamond eye straight pipe, tymar intake, tony wildman tunes, intercooled, boost and pyro gauges, looking for more mods soon
  #2
Old 10-30-2020, 03:45 PM
Addicted4 Addicted4 is offline
Lieutenant
Member's Gallery
Default
Check the ipr screen?
  #3
Old 10-30-2020, 03:47 PM
CJunkie's Avatar
CJunkie CJunkie is offline
Corporal
Member's Gallery
Default
Kinda curious what oil you're using now. Don't know if I would worry about it, it's a good reminder to change it I guess
Sent from my LM-V350 using Tapatalk
__________________
97 F250 SCLB 7.3 4x4, 303k and counting
zf5, 6637, TS chip, dual 4" straight pipes
Currently looking for axles for an 05+ swap.
  #4
Old 10-30-2020, 04:18 PM
Sergeant
Member's Gallery
Default
I'm using the t6 full synthetic, I thought maybe the screen but why would it only happen when my oil gets older
__________________
  #5
Old 10-30-2020, 05:19 PM
Lieutenant
Member's Gallery
Default
If the screen is partially plugged fresh oil will flow thru it easier than dirty oil. Also you could be having a fuel dilution issue with the injectors spilling over into the oil. 6.0 have fuel dilution of the oil more than other engines.
I would also possibly switch oil to LE 8700. Call or text jim k and he will get you set up.
  #6
Old 10-30-2020, 05:21 PM
Lieutenant
Member's Gallery
Default
And what problem are you having besides ipr duty cycle going up as oil gets contaminated? How does the truck run, drive, start cold and hot?
  #7
Old 10-30-2020, 05:54 PM
Sergeant
Member's Gallery
Default
none really it feels like it idles a bit different but everything feels the same
__________________
  #8
Old 10-30-2020, 05:55 PM
Sergeant
Member's Gallery
Default
and my oil level never moves so I don't think I'm getting fuel into my oil
__________________
  #9
Old 11-04-2020, 07:20 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
We switched to driven oils LE has changed some stuff. Pm me or get ahold of jim for info. Im his shop manager. Have been for 6-8 months now. Lol
live life full throttle
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #10
Old 11-04-2020, 07:22 PM
General
Member's Gallery
Default
Quote:
Rotella is the worst fukin oil to run in a heui system. Period. Let me know if i can help.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
