Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #121
Old 08-11-2016, 07:11 PM
Cheap6.7's Avatar
Cheap6.7 Cheap6.7 is offline
Lieutenant
Member's Gallery
Default
Quote:
Originally Posted by Tom@BigTimeKustomz View Post
Morgan, or any guys that are just running a StreetMax and '15 pump, are you seeing any issues with other parts? Thinking this is where I'm going with my truck over the winter. Don't want a crazy hp truck, just a nice reliable daily driver. My truck currently is fully dereeted and canned tunes on the SCT.
Thanks for any help.
No issues here other than I want more power now....
__________________
2011 CCLB with a turbo ****** and a *** ****** along with *** ****** and tinted tierod sleaves with my mirrors up and muthafukin CAMO seat covers!
  #122
Old 08-11-2016, 07:27 PM
peont's Avatar
peont peont is offline
Private
Member's Gallery
Default
So at what horsepower are you on borrowed time with the stock internals of the engine? The reason I am asking is because I been looking at the StreetmaxR and the Barder 6670 setups. I am going to add H&S dual fueler and lpfp for whatever turbo setup I go with but keep stock internals.
__________________
2013 F250 Crew Cab 4X4, Ezlynk, No Limit Fabrication Goodies, Midwest Diesel Goodies, H&S Goodies, and 7" PMF Lift Kit With Upgrades.
  #123
Old 08-11-2016, 09:21 PM
Morgan@Midwest Diesel & Auto's Avatar
Morgan@Midwest Diesel & Auto Morgan@Midwest Diesel & Auto is offline
General
Member's Gallery
Default
Quote:
Originally Posted by maxxedout View Post
Has anyone tried a 6670R WITHOUT dual fuelers, or is that a complete waste?
Yes, plenty have them with a single pump. If you plan on more in the future it's ok. Otherwise the only gain will be sound.
Quote:
Originally Posted by bigrpowr View Post
i think its a good bit more turbo than stock fuel could use, but maybe morgan can confirm.
Stock "2015" fuel is good for around 600 on most dyno's. You can over turbo it and still only gonna make that same power. So yeah.
Quote:
Originally Posted by JRLott View Post
I can see them making similar power since both provide more air than the fuel can use, but I wonder if the 6670 would be more sluggish and slower spooling.
Similar power. Both spool well. But you do give up some cruising egt's and tip in response with the bigger charger.
i'd say to a point yes, but a turbine is a turbine. the barder will spoool slower. i think if you dont have a plan for dual fuel in the immediate future , its alot left on the table in spool and money .
This^
Quote:
Originally Posted by SVTDiesel View Post
So once the duel fuelers or other system that someone uses to up the fuel for the 6670; what is the hp gain over the streetmax R? If that makes sense? So if you can get w/o fuel 650 with the SM-R, is it worth the extra $1700 for the 6670 as well as $3500 conservatively for duel fuelers to only gain 50-100 at most rwhp? Thanks!
The dyno's we've been using are showing 540 stock 15 charger and pump, 600 with 65.5 and 650 with 65.5 and added fuel. On average.
6670 and fuel probably good for 700 ish. Built engine ported heads bigger injectors we've seen 750.
If that helps.
The StreetmaxR should be in the 650 range with fuel, or roughly 50 more than on '15 fuel. The 6670 should get you to about 750 with fuel. If you're buying the extra fuel anyway...may as well go with the 6670. Just my opinion, but I could see a case for staying with the StreetmaxR, since it won't make enough power to satisfactorily destroy internals and the 6670 is pushing the hell outta that limit.
Yep.
With aggressive fueling and poor driving habits, either can spit rods... But then again so can a s366 or stock charger.
Quote:
Originally Posted by sootie View Post
"with fuel" is a very loose term. Not gonna hit 750 with a 6670R on stock nozzles...
Not on most dyno's. Some on the east coast may..
Only real "weakest link" is the Trans. Which at some point will give up. But we have plenty of fixes for that!
  #124
Old 08-11-2016, 10:17 PM
JRLott JRLott is offline
Major
Member's Gallery
Default
Well, yeah. You can only get so much fuel through a given orifice. Thought we were talking about turbo capabilities.
__________________
2015 F250 Lariat FX4 CCSB
  #125
Old 08-11-2016, 10:32 PM
Major
Member's Gallery
Default
Quote:
I would love a StreetmaxR, but I'd probably need a built motor. I should probably be driving my tow tune now, since I drive like a dipsh!t. Hard to put the genie back in the bottle, though.
__________________
  #126
Old 08-12-2016, 06:29 PM
General
Member's Gallery
Default
I have guys that I have tuned with stock engines and Trans dual pumps and 65.5's with good luck. Just have to tune accordingly.
  #127
Old 08-12-2016, 07:28 PM
peont's Avatar
Private
Member's Gallery
Default
Morgan how are the trucks running the barder 6670R on a stock engine holding up? Will I need to build my engine or transmission to handle the horsepower that the barder 6670R is capable of?
__________________
  #128
Old 08-13-2016, 07:32 AM
General
Member's Gallery
Default
Quote:
Just fine. You do need tuning specifically for that turbo. Had a guy running standard 2015 tunes with really aggressive low end fueling and the incorrect vane position knock the rods out of one a month or two ago. They don't operate like a 15 charger. About as bad as running a 15 charger on 11-14 stock turbo tunes.
  #129
Old 09-04-2016, 02:49 PM
bpan's Avatar
bpan bpan is offline
Sergeant
Member's Gallery
Default
So what is a 11 pump going to run on a 65.5? 5 50 is before running out of fuel?
  #130
Old 09-04-2016, 09:34 PM
General
Member's Gallery
Default
Quote:
Roughly. Have seen mid to upper 500's.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
