Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 05-04-2020, 11:29 AM
BIG JUICE's Avatar
BIG JUICE BIG JUICE is offline
Lieutenant
Member's Gallery
Default Wiring Harness removal after ecm block off
Hello guys, got the blank ecm connector to plug up the right most connector when looking at the firewall. I am wanting to pull the entire harness related to weight reducing efforts on the passenger side of the truck. Any special tips to getting this off with least effort or fckn things up? thank
__________________
2015 F250 platinum, flopro 5", jones turbine 5050xl, polished No Limit intake piping & intercooler, jenny craig, sotf gear hedd tune, Rigid DOT fogs, Chinese 40" radius led, Amp steps, weathertechs, Edge CTS2, titan tank, Dieselsite fuel & coolant filter, Blue ox gooseneck, Hellwig bars, retrofit projectors, Linex plat, Retrax cover,full Carli 2.5" backcountry, Fox 2.0 res shocks, Toyo RT 37", OUO ala, bars, truss, levelers
  #2
Old 05-04-2020, 12:40 PM
Swaan's Avatar
Swaan Swaan is offline
Lieutenant
Member's Gallery
Default
That whole entire harness might weigh a couple pounds?
But if you set on doing it then it's just a matter of doing it. Nothing really to look out for. Just start from the front work your way back
__________________
E97 f250 ECLB. SOLD!
Dana 60 front with rsk kit. 5" blocks in rear. 4:10 on 35s. Blackwater reman 7.3 with arp studs , comp springs. 175/80 pis inj, adrenalin hpop,irate fuel system with fuel lab pump. Borg warner 364.5 fmw with 1.00 a/r housing. EC450 horton electric fan clutch. ZF5 shaker.
--16 f350 ccsb lariat 6.7 tuned and D-leted!!😈
--15 VW passatt TDI sport. Tuned and D leted 6 speed
  #3
Old 05-04-2020, 03:42 PM
HeavyAssault's Avatar
HeavyAssault HeavyAssault is offline
Major
Member's Gallery
Default
Is it it's own harness?? I didn't commit to memory since most of those bundles are interwoven to a certain degree. I thought I was lucky to get the DEF harness out of there. The main connector is on the left side while it runs over to the right. SO that would say there's a portion of the emissions harness that splits and runs to the ***/SCR, then runs to the DEF tank area.
  #4
Old 05-04-2020, 07:37 PM
StrokiNDieseL's Avatar
StrokiNDieseL StrokiNDieseL is offline
Lieutenant
Member's Gallery
Default
Haven’t done so but heard the inner connection closet to engine is what’s removable.
__________________
Slow stock 17 F250 6.7L Ccsb Lariat ez lynk Em on tooning 75hp, Pmf reverse level.
08 Sclb 6.4 Farm truck Minimaxx on a diet (project 6far)
08 F250 Built 6.4L CcSb Lariat 3.73 Dyno'd 704rwhp/1220tq. SOLD
  #5
Old 05-12-2020, 06:00 PM
Major
Member's Gallery
Default
Sure you can disconnect the PCM connector, but remove that connector and wire bundle thru out the whole truck harness?? The DEF tank is one one side, ***/SCR on the other.....that emissions bundle splits somewhere near the motor.
  #6
Old 05-13-2020, 04:56 PM
BIG JUICE's Avatar
Lieutenant
Member's Gallery
Default
haven't attempted it yet, I have been doing brake work on my days off. I'll try to get on it asap and post some pics.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
