Go Back   PowerStrokeArmy > Classifieds > Aftermarket Performance
Reply
Thread Tools Display Modes
  #1
Old 07-24-2015, 04:50 PM
dentexpowerstroke's Avatar
dentexpowerstroke dentexpowerstroke is offline
Major
Member's Gallery
Default 7.3 go fast parts
Parting out my race truck, most parts have 1 season on them unless specified. All prices are obo.
Truck made 715hp with all parts listed and running an 80mm s400
Bts 4r100- $4500, has about 7k miles and 1 race season since rebuild
Terminator dual hpop- $1200
Farmers 400/400- $1200
Di headers ceramic coated - $1000
Php hydra- $300
Isspro ev2 black face/bezel 100psi boost, 2000* egt and 280* trans temp guages- $300
Arp studs, 2 torques on them- $250
Comp beehive valve springs(and necessary parts to run them)- $150
Di pushrods- $150
4 line feed regulated return- $250
Billet flexplate, sfi approved- $275
Aeromotive a1000, ran with 10 micron prefilter it's whole life- $150
Hypermax t4i turbo mount, will throw in the turbine housings to run 96/88 turbine s400s- $850
__________________
01 f250 ccsb 4x4 400/400, twin terminators, s480, bts and supporting mods --- sold
2006 ccsb f250 155s and powermax
2012 ccsb lariat ultimate
  #2
Old 07-24-2015, 06:14 PM
campbellflage campbellflage is offline
Lieutenant
Member's Gallery
Default
best price shipped for the headers? 34667
__________________
2000 DRW CC 7.3
Exterior: 08 clone, 22.5 alcoas
Engine Mods: T4 366, 5 inch exhaust,T500, 6637, TW tunes, fluidampr, melling lpop, custom fuel 6.7 fuel pump
Trans Mods: 6.0 trans cooler, JW Valve body,Billet triple disc converter.
Cts2 for Guages
In the garage waiting for install: swamps 300/200, gen3 hpop, studs, beehives, pushrods
  #3
Old 07-24-2015, 07:53 PM
97f350stroker's Avatar
97f350stroker 97f350stroker is offline
Major
Member's Gallery
Default
Wish I could get that dual hpop set up off ya glws
__________________
97 cclb f350 zf5, Southbend DD, 468, 250/80's, studs, springs, pushrods, e-fuel, adrenaline, traction bars
95 rclb back to stock motor, sky rsk, sd axles, 20's and 35's
  #4
Old 07-24-2015, 09:39 PM
Powerstroker7.3's Avatar
Powerstroker7.3 Powerstroker7.3 is offline
Lieutenant
Member's Gallery
Default
What egts did the headers see usually. Are there any signs of warping
__________________
350/200 custom 75mm bts 4r100 fully built motor by PDP
7.43 @ 94 CCSB
  #5
Old 07-24-2015, 10:20 PM
Strokersace's Avatar
Strokersace Strokersace is offline
Colonel
Member's Gallery
Default
Built block this stuff was bolted to? Or did it pop?
__________________
I'm sweatin' like a wh*re in church here!
  #6
Old 07-24-2015, 10:25 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
Moving on without the 7.3?
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, S471, Beans IDM, ARP head & main, girdle, half filled block, DI cam, Dual IPRs, ceramic coated bowls, anti-friction skirts, Haldex pump over Stock pump, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #7
Old 07-24-2015, 10:42 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Quote:
no need to watch egts cuz racetruck
Quote:
no pop.. he figures he could part it out easier then selling together.
Quote:
he's a bich and getting out of it.
bump for ya D..
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #8
Old 07-24-2015, 11:02 PM
Colonel
Member's Gallery
Default
bump for ya D..
Well is it a built short block? I've already got the bolt on stuff...
__________________
  #9
Old 07-24-2015, 11:44 PM
General
Member's Gallery
Default
stock forged
__________________
  #10
Old 07-25-2015, 06:00 AM
Lieutenant
Member's Gallery
Default
My brother has a set of these headers and he has warped his to the point where he breaks the bracing. So I just wanted to know if there had been any signs
__________________
7.43 @ 94 CCSB
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
