Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #1
Old 11-29-2017, 02:10 PM
PDT1081's Avatar
PDT1081 PDT1081 is offline
Major
Member's Gallery
Default P0404 and P2552
I know P0404 is probably a dirty EG R. Runs a little rough occasionally and dad just puts his foot on the floor to "try to clear it out." I shake my head, but it's his truck. Any chance the P2552 is caused by that, or am I looking at two different issues? He's going to stop and either get a new valve, or just a seal kit. I'll clean it out once he gets the parts.
05 with roughly 150,000 miles, bone stock.
  #2
Old 11-29-2017, 02:40 PM
046.ohBills's Avatar
046.ohBills 046.ohBills is offline
Sergeant
Member's Gallery
Default
unsure of the p2552 but all he needs is the o ring kit and to clean it out. should be good for the egr code
__________________
04 F350 CCSRW-Studded, Decked, DieselSite Adrenaline HPOP, Driven Diesel RR, Coolant Filter, Leveling Kit, Riff Raff IC Boots, HD Alternator
Cosmetics- 07 Harley Lights with HID lights, Light bar in Grill, ABS black Mesh grill
  #3
Old 11-29-2017, 05:53 PM
PDT1081's Avatar
Major
Member's Gallery
Default
Quote:
That's what I'm hoping. The P2552 is "throttle/fuel inhibit," which searching has only brought up FICM problems, and seems to be mostly after replacement.
  #4
Old 11-30-2017, 06:05 AM
Sergeant
Member's Gallery
Default
Exactly, either that or wiring that deals with the ficm or injectors. Could try cleaning the ficm connectors and see if that helps.
__________________
  #5
Old 12-03-2017, 11:53 AM
Wrxeac Wrxeac is offline
Private
Member's Gallery
Default
Might check to see if the FICM connectors are full ‘clicked in’.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
