Go Back   PowerStrokeArmy > Power Strokes > Aftermarket Super Duty 1999 - Current
Reply
Thread Tools Display Modes
  #11
Old 06-16-2018, 10:51 PM
Sterling6.7's Avatar
Sterling6.7 Sterling6.7 is offline
Lieutenant
Member's Gallery
Default
Quote:
Originally Posted by junglejoe View Post
Ok.. I'm color blind and need help.. What color are these two wires? I pulled door panel off and everything matches up.. But I need a brown wire for the marker lights.. The two yellow wires get crimped together if I read the wiring diagram correctly. ..
Now the factory plug.. Is there a brown wire in there..maybe that single one?
In the photo, the curved one is brown, the shorter straight one is red. The second photo is not clear enough to accurately make out the colors.
__________________
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray
  #12
Old 06-17-2018, 12:22 AM
co04cobra's Avatar
co04cobra co04cobra is online now
Sponsor
Member's Gallery
Default
What year mirrors are you installing?
The brown wire on truck side should be park. Iirc, wire the yellows together. Colors changed slightly left to right also I think.
__________________
00 cc/sb zf6 F250- Some stuff done always more to do-Fuel 300/200s Air-Garrett 68/94-Oil SRP 1-Airdog to Fuellab
97 cc/sb- zf-5- Work in progress. PMF rsk w/ SD axles. 66 turbo, E fuel, 230/100s. SB DD clutch.
08 cc/sb - Elite bottom end - 2 fuelers, 59vgt/78atmo, Midwest 100% nozzles and coated heads etc....
www.teddavisautos.com
Many parts available for super duty trucks PM me.
  #13
Old 06-17-2018, 12:35 AM
junglejoe's Avatar
junglejoe junglejoe is offline
Sergeant
Member's Gallery
Default
The mirrors are off of an 05
__________________
06 CC Long bed FX4---- 11 inch 4 link RC lift w/dual front shocks 37 inch Trail grapplers w/ dual steering stabilizer's
SCT Live Wire w/ I n n o v a t I v e Diesel Tunes
S&B air Intake
5 inch exhaust w/muff and cat gone
RCD 155/30 injectors w/ regulated fuel return
Stock turbo(32lbs of boost)
  #14
Old 06-17-2018, 12:38 AM
junglejoe's Avatar
Sergeant
Member's Gallery
Default
Quote:
👌 thanks. In the very first post.. that is my factory truck plug.. the bottom wire to the right.. is that the brown wire if you can tell?
__________________
S&B air Intake
  #15
Old 06-17-2018, 08:02 AM
Lieutenant
Member's Gallery
Default
In your first post, first photo, the wire to the right with the slight bend appears to be more brown than any other wire in the bundle. Left to right - green/purple, black, green/white, blue, yellow, red, brown.
__________________
  #16
Old 06-17-2018, 08:35 AM
junglejoe's Avatar
Sergeant
Member's Gallery
Default
Thanks.. Normally when I work with wires.. I have to double tape and mark the wires on which on connects to what and it just works for me.. But I bought these mirrors from a guy who put 08 mirrors on his 05 truck and he cut the plugs off to put on the 08 mirrors.
__________________
S&B air Intake
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
