Cab marker lights install
Homesteader
Any other brands out there that is as good as OEM for cab marker lights for 01 SD? Thinking of doing OEM but would like to know if there is any other good quality kits out there. Also can the light bulbs of the OEM light be upgraded to such as LED bulbs? I would like to run smoke lens if they have it for the OEM mounting base.
Thanks
psdguy95
Effingham, IL
I had a recon set on my last truck. They worked really good for me. No water got in them like i had read and herd from people.
psdguy95
Effingham, IL
I believe they are similar to OEM. I mounted mine my own way. Just to be different. You can use oem ones and just swap out the bulbs for LED's and smoked lenses.
co04cobra
WV
Factory bases with smoked lenes, and led 194 bulbs IMO. I have uninstalled or had to fix numerous leaks, and just general problems with the aftermarket ones.
