wjamesm
Like the title says i have a leaking oil pan , oil drips are on all the pan bolts on both sides . I did look above it to make sure it's not the bedplate leaking . My question is can i remove the pan with the engine in place ? I search here and Googled to see if there was a write up anywhere on the net . the only thing i ran across was one person said the engine had to be pulled and another said it was doable and was a flat rate of 2hrs at the dealership . Truck is an auto and only has 60k on it .
