Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #41
Old 06-24-2017, 10:28 AM
Jerrybizzle's Avatar
Jerrybizzle Jerrybizzle is offline
Private
Member's Gallery
Default
95 psi they were at? What's the max for the tire?
__________________
2012 f250CCLB, 2 inch lift, 35s on 17s
Dropped weight and mini maxx
  #42
Old 06-24-2017, 10:51 AM
TrickTruck's Avatar
TrickTruck TrickTruck is offline
Sponsor
Member's Gallery
Default
80psi
__________________
2016 F350, 6.7L Diesel, 4x4, SRW, Crew Cab, Short Box, Platinum, Ingot Silver
Unlimited Engineering SuperArmor! Warn 16.5Ti w/ synthetic line.
Ultra 22x10 and Nitto Ridge 37x12.50R22, Leer XL, Icon leveling springs, steering damper mounts, King reservoir shocks and steering damper, PMF Traction Bars, Titan 50gal tank. Airlift airbags and wireless dual controller, AMP Steps.
Stuff to install: Detroit Truetrac, aFe 5", NL Intake,
For sale: Brand new BD Exhaust Brake
  #43
Old 06-24-2017, 01:15 PM
Private
Member's Gallery
Default
Quote:
Originally Posted by TrickTruck View Post
I guess I'd just call it a very loose feeling in the back of the truck.
As it turns out, Discount Tire will !NOT! replace the tires. They say that the TG2 does not have enough weight rating for an F350. My statement that I'm not so stupid to overload my tires got nowhere and there is no other tire which fits a 22" wheel and is capable of the weight rating of an F350.
Whatever.
I did notice that when I checked the tires in Knoxville and found them to be inflated to 95psi, I dropped them to 70psi they seemed better.
So while sitting at Discount Tire I made them call Nitto and get a load chart for these tires.
Dropped them to 60psi and it's better. Went to the CAT scales (truck is a pig at 9800lbs w/ a full tank of fuel) and by the weight of the vehicle and the load chart I could drop them another 10 psi and still be safe.
Likely my mileage would suffer as well and it's already pretty horrible at 14.5mpg (corrected by 5% for the larger radius) running empty at highway speeds.
Makes no sense to me that dropping psi makes the tire perform better in the corners and sway, but it's hard to argue with what's happening.
But they had them at 95psi? That could have been part of the problem! Unless you meant 75. I figured they were 80 max.
__________________
  #44
Old 06-24-2017, 02:42 PM
TrickTruck's Avatar
Sponsor
Member's Gallery
Default
No. I made it to knoxville (after scaring the crap out of me on the I40 pass) and stopped to check them. The fronts were at 75psi and the rears were at 95psi. I dropped them all to 70psi and things got better. Once I'd seen a load chart, I dropped them to 60psi and they got mo' better. According to the load chart, I could drop them to 50psi and be right on the money - empty.
__________________
  #45
Old 06-24-2017, 08:38 PM
ckrueg's Avatar
ckrueg ckrueg is offline
Lieutenant
Member's Gallery
Default
If your not loaded I would drop the rears down lower than the fronts. The weight distribution on theses trucks is like 60/40 or worse. I run my rears at 40
  #46
Old 06-25-2017, 07:07 AM
WHY NOT's Avatar
WHY NOT WHY NOT is offline
Colonel
Member's Gallery
Default
Hopefully they stop walking on you soon. Mine never did it, and are great when loaded. I really like my ridge grapplers. This is going to sound backwards but I run 55psi up front and 62 in the rear unloaded. I did the same thing lower in the front and higher on the rear on my ATZ's when unloaded as well and got 50K out of them while also doing some pretty heavy towing and rotating every 5K. But the Ridge Grapplers are much more stable than the ATZ's ever were.
__________________
Matt
2011 F350 6.7L CC/LB SRW 4x4 King Ranch White Tri Coat
Midwest, NL, GH - OUO/Icon 3.5"/6" on 20x12 Weld Cheyennes w/ 35x13.50's
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
Designed by Military Ltd
