To CCV mod or not to CCV mod, that is the question
95cobby
Houston
Not looking to start any pissing matches but have you guys seen this? I usually watch Bill's videos as they are very informative but this one seems to have caused quite the cluster fock if you read all the comments. Found them pretty entertaining actually. The argument seems to be that the higher rpm is causing excessive pressure on the turbo seals with the CCV mod installed. I have owned several FI sports cars, both blown and turbo including a twin turbo s550.. with all those cars running open system catch cans.. but then again none of those cars were making 30-40lbs of boost so I have no idea if what Bill says is correct or true. It makes sense in theory but I have yet to see or hear anyone else stress this concept. Is Ford's AOS really letting that much oil pass through? Has anyone installed a catch can between the intake and the CCV to check?
http://www.youtube.com/watch?v=4Qu2-Dr3jF8
04cr450
harford county, maryland
Well I won't get into it because I am not educated enough to back this up but: spoke to a ford engineer about this months ago and to do a Ccv ****** on a 6.7 is a bad idea in the long run(I have a Ccv mod kit still on the shelf new collecting dust).
I still scratch my head as to what to do. 6.7's have an excessive amount of blowboy compared to the other model enfines in the ford lineup. Also that Ccv collector/dog house oem box although looks simple is not and was spent countless hours designing it to attend to the 6.7 blowby. It is their for a reason. I honestly forgot the multiple amount of reasons it was designed like that- I don't listen well when talking to an "engineer"
Wanted to add - had a Ccv ****** on my 6.0 for years- had an engine oil leak even on a new build motor... put the Ccv back in place, leak completely stopped.. true story
95cobby
Houston
The Ford CCV is an air oil separator where it allows the gasses to pass through and drops the oil back into the crank case. It's a sealed design unlike the Dodge 6.7 ccv where they replace the filter more often. On ours we are supposed to replace that whole box after 100-125k miles or so. I have no problem with the gasses passing through but I don't want the intake or CAC getting puddles of oil in them.
Although it would be pricey and take a bit of fab work I could prolly get a Radium AOS hooked up in place of the CCV. But it seems pretty promising if Ford's AOS is able to last 100k+ miles before needing to be replaced. Just not sure how much oil is actually getting past it.. guess I could pull my intake tube and look.
dcswetman
Girard, GA
Removed mine at around 75k because I had oil getting past the the box. I had oil in my CAC and all. Truck was bellowing white smoke when I'd let out the throttle. Did a No Limit CCV delet e and it solved the problem
HeavyAssault
Middle, VA
I'd argue that LONG ago back in the old big block days there wasn't an issue going to atmo. To say things back then had tighter tolerances compared to today might be a stretch as well.
I'd think as long as you can get the pressures close to OEM what's the problem.
CATDiezel
Two ways to look at it.
97% of the trucks out there are non-deIeted. And have no idea about the items to do so...
There are zero side affects of leaving it in place. I leave mine in place because I really don't care. Won't keep the truck long enough to worry about it..... even if I did keep the truck forever still not worried about it.
The other option is to remove it to atmosphere and have one more thing to keep up with.... for what? Or put the ventura kit on in line of the exhaust.
Just drive and enjoy!
Kxc
South Jersey
I removed my CCV box at 12k and the turbo piping and CAC had a good amount of oil in it. I think the way to go is Venturi in the exhaust through a catch can. I use a small racor unit. When you get on it and there is any blow by the Venturi should keep the crank case pressure at a reasonable level and keep the oil leaks to a minimum .
jwalk09
VA
Had mine rerouted to the atmosphere for awhile but plugged it back in.
95cobby
Houston
I'm kind of in that same bucket, don't really care all that much but I don't want oil accumulating and coating all the piping. If I do run an open system I don't want to cause any extra stress on the turbo.. although I guess eventually that would give me an excuse to upgrade. I think the venturi is currently the only way to ensure there is at least some vacuum on the re-route. Just not sure how that pressure compares the ccv being routed to the intake currently.
Yea I'm at about 14k now and I'm sure there's some oil in both, just the nature of the beast. The venturi and catch can is prolly as close as you're going to get pressure wise without routing back to intake. How much oil is your catch can collecting?
i would avoid powerstroke help videos...
Lol, I may just do that :thumbup:
Sportchassis06
Been running mid sized racor unit,no venturi for over 75,xxx miles.No leaks here.The venturi is over kill....
95cobby
Houston
So you guys using the Racor units.. are you draining the oil back to the oil pan as well as running the outlet side back to intake? Or do you have a canister hooked up to catch the oil and the outlet vented to atmo?
Kxc
South Jersey
My racor is in line to the Venturi. I drain it when I change the oil. I don't drive much so that's every 2000 -3000 miles for me.
Jomax
Arizona
I chose not to mess with it. I can't stand the smoke of smell.
I'm sure the truck will still make it to 200k.
JetExpress_6.7
Just an opinion here...but leave the factory box on, remove the line from it to the intake, cap the hole in the intake, buy a vinyl 1" hose and slip it on where the hose came off the box and you're done.
Lets the factory box do its separation job, 1" line is plenty big enough to vent pressure, and it all cost you about 8 bucks and 30 mins (if you're working slow...)
BIG JUICE
Valrico FLA
What I'm doing currently, then into exhaust venturi
