Zf5 dual disk clutch and T6 mount
bens
Custom built by kentucky clutch, it is a dual disk sintered iron clutch I had spec'd for 1,000hp. Billet flywheel, all sfi certified. Clutch has around 20 pulls on it.
It's just been sitting on the shelf since I went with a cummins powerplant.
$850 obo
Fabricated T6 turbo mount for 7.3, using obs manifolds. To run a big T6 s400 charger. Comes with oil feed and drain fittings also. Can include the 5" hoodstack pipe also, you would just need to weld on a 5" marmon flange. $400
Thanks for looking,
Ben
Sent from my SM-G892A using Tapatalk
