Go Back   PowerStrokeArmy > The Bunker > General Discussion Forum
Reply
Thread Tools Display Modes
  #11
Old 07-29-2018, 09:40 AM
PDT1081's Avatar
PDT1081 PDT1081 is offline
Major
Member's Gallery
Default
Quote:
Originally Posted by Jonnydime View Post
The simple fact that Im going to build a triple setup for my truck and I already have three very expensive ball bearing turbos that I could use. Its one of those I already have this stuff so why not use it moments. Sure I could sell the largest of the three at a loss and buy another mid sized unit but why.
Are they close in size? I think problems may arise if there is a big size difference, you could easily push one out of its efficiency range. It'd be interesting to see a dyno session where you could block off one of your atmosphere turbos. Then add the other turbo and see what happens.
Personally, I'd be prepared to make the change to two identical atmospheres, but why not give it a shot.
  #12
Old 07-29-2018, 10:29 AM
Jonnydime's Avatar
Jonnydime Jonnydime is offline
Major
Member's Gallery
Default
Quote:
That's how I see it. I'm building the setup so having to modify it won't be that big of a deal.
  #13
Old 08-02-2018, 07:14 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Why not use the smallest one and the biggest one and not use the middle one and sell it for other parts? Do a normal compound setup. Not 2 atmospheric and one high pressure... or if they are far enough apart in size then why not compound them all? A Low a mid and a high pressure turbo.
live life full throttle
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #14
Old 08-03-2018, 06:22 AM
Jonnydime's Avatar
Major
Member's Gallery
Default
I did that with my red truck. The setup was nice but I'm not one to do the same thing twice. Uniqueness with functionality is what I'm after.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
