6.0 zf6 manual conversion with South bend dual disc
1ofakind79
Herminie PA
Selling a 6spd ZF change over from a 05 f250 4x4.
Includes:
Transmission, transfer case (electric shift), transmission harness, cross member, shifter, floor tunnel, column, front driveshaft, front portion of rear shaft, peddle setup, new South bend street dual disk (1000 miles), soundbend hydraulics, block plate (different from an automatic) starter, ECU, bolts & hardware.
Located at 15637 zip. SW PA
$2800 for everything
