2005 superduty auto locking hubs over ride.
97CenturionCrew
OK on the 2005 f350, the hubs are auto or manual locking. What is needed to provide power to lock the hubs using the factory plug? Anyone have a diagram on this? I am working out details on a OBS swap with '05 f350 axles and wanted to be able to engage the hubs from the cab. Is it just a 12v that can be operated from a relay? thanks
stroker_1999
Get you a vacuum pump and a revisor from a superduty then build a switch panel to operate the vacuum pump you will also need the vacuum solenoid that feeds the auto lock hubs.
