Go Back   PowerStrokeArmy > Power Strokes > 94-97 Aftermarket
Reply
Thread Tools Display Modes
  #11
Old 10-21-2019, 12:17 AM
JCart JCart is offline
Sergeant
Member's Gallery
Default
Quote:
Originally Posted by mandkole View Post
Did you drive the truck? Got the air out of rails? Does it run poorly?
No gonna wait for FFD 205/30% hybrid injectors, they are on route.
j
__________________
'97 F250 ECLB Tan White Tan Now ZF5 , 4:10s, D60, PMF 3.5 RSK, 37 Toyo RTs Anti sways front/rear w rear bags 5 blocks (184,000 Kms) DP, intake and 4 exhaust, FFD 205/30s, Hydra, E fuel.
Truck pix & Write ups
  #12
Old 11-02-2019, 05:51 AM
Sergeant
Member's Gallery
Default
Installed FFD 205/30s nuthin... changed back to know IDM 120 volt... nuthin, changed back to know IPR, nadda. Valve covers off checked for oil out injectors nuthin. Just for the fun of it thought I’d check the HPOP output with hose and 5000 psi gauge, hooked it up to passenger head.... nuthin. Swapped out HPOP to stock one off this truck, plus same IPR, cranked a bit after topping up HPOP Reservoir....Bam 3000 psi, plugged in jectors, fires right up and runs smooth, idles just over 500 psi rail oil pressure. Was late so packed it in for the night. Surprised at how smooth it idles even with air in system... phphfew... will clear and see if it throws any codes in the morning and button it up. Pretty excited on a number of fronts. Will send out T500 and 175/80s for testing.
Thanks for support guys.
j
__________________
  #13
Old 11-02-2019, 07:42 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is offline
General
Member's Gallery
Default
Right on man!
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #14
Old 11-03-2019, 12:04 AM
Sergeant
Member's Gallery
Default
Logged a few kms this afternoon, man holyyyy kinda forgot messin with jector swap and the no start cause a fair amount of fuel and oil to migrate into exhaust.... can you say frickin huge... huge clouds of smoke, blocked out 2 full lands on 4 lane highway burning it off. ��������. I was even duckin down.... hahahaaa. Cleaned up good though. Now for more appropriate files, most current I have are for the 175/80s so should be able to release a little more.... idles so nice, runs really smooth.
What are you guys using to replace the tinfoil flex heat shield covering passenger side over heater box area? Mines looking kinda tires and ratty... next up gauges and IC.
Cheers,
j
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
