Go Back   PowerStrokeArmy > Power Strokes > Aftermarket Super Duty 1999 - Current
Reply
Thread Tools Display Modes
  #11
Old 11-28-2011, 12:19 AM
Ron's Power Stroke's Avatar
Ron's Power Stroke Ron's Power Stroke is offline
Lieutenant
Member's Gallery
Default
looks to be about the same size hole as a stocker..if it is, it will be a 22MM X 1/2 thread, it can be drilled with the R drill bit that was left from your pyro install and tapped with the 1/8" NPT tap that came from same install..i think this was the same as an oil plug for the cumaparts..you will also need a crush washer or an oring to help seal the plug..this is how i did mine and it cost under 8 bucks..
__________________
Early 99 7.3 F350 auto,TN T-4 mount with a s467 thanks to unlimited diesel..beehives, DI push rod's, new alliant 315/200 hybrids, Driven diesel fuel system with a fuel lab 41401...tuned by ********..
88 F250 7.3 IDI plow truck 112k- bone stock
  #12
Old 11-28-2011, 07:03 PM
Dmstrucks02's Avatar
Dmstrucks02 Dmstrucks02 is offline
Colonel
Member's Gallery
Default
Quote:
Originally Posted by 01platinum View Post
Yes that will work. Now what color??? Haha thanks
01Platinum's Command Center
I would say black or bare aluminum
__________________
02 CCSB X code leafs with full traction hangers on 35s
Stock motor, stock trans with TransGo valve body mods, Mishimoto trans cooler
Full Force 238/80's, Irate Diesel T4 kit, S366SXE
OUO weld on traction bars
Texas Tuned
5" MBRP
Isspro gauges
  #13
Old 11-28-2011, 11:22 PM
01platinum's Avatar
01platinum 01platinum is offline
Major
Member's Gallery
Default
Quote:
I ordered the black one. Ready for it to get here so I can install the intake plenums and spyder. Going to be an interesting day is all I can say.
__________________
2001 Platinum Edition
Mods: Changing everyday
SDRCM#999
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Designed by Military Ltd
