6.0 and 7.3 parts - injectors, hpop, turbos, etc
turboTwang6
Holland Patent, NY
6.0 parts
205/75 injectors, used, they have a couple thousand miles on them - $1200
s364.5 fmw, .83 divided housing - $800
5" intake with boots - $300
T4 up pipes - $300
7.3 parts
Gen3 style hpop - $800
H11 studs/springs/pushrods - $600
Arp main studs brand new - $300
s475, 93mm turbine, t4 1.25 and t6 1.32 housings - $800
Air to water intercooler with water pump - $400
Air piping for IC and turbo - $300
3" plenums - $200
Fass pump and IH filter head with braided lines - $500
Reg return, all braided lines, homemade - $200
South bend sintered iron DD clutch - $1500
Aluminum master/slave setup (obs) - $200
Zf5 tranny + transfer case - $1000
Front and rear axle with 4.56 spools - make an offer
Misc other parts that are ideal for a pulling truck.
Also have the whole truck to part out, or take the whole truck with all the parts for $6500.
I'll try and post some pictures.
You can text or call at 315 525-3591
Thanks
turboTwang6
Holland Patent, NY
turboTwang6
Holland Patent, NY
Updated prices
6.0 parts
205/75 injectors, used, they have a couple thousand miles on them - $900
s364.5 fmw, .83 divided housing - $700
5" intake with boots - $200
T4 up pipes - $250
7.3 parts
Gen3 style hpop - $700
Air to water intercooler with water pump - $350
Air piping for IC and turbo - $250
3" plenums - $200
(Sold)Reg return, all braided lines, homemade - $200
Thanks
