Go Back   PowerStrokeArmy > Power Strokes > Aftermarket Super Duty 1999 - Current
Reply
Thread Tools Display Modes
  #6621
Old 06-06-2017, 09:19 PM
smcox1's Avatar
smcox1 smcox1 is offline
Major
Member's Gallery
Default
I don't think they make any that are deep enough for the older trucks but I'm not 100% sure. If you just paint the hub black it won't look bad at all.
__________________
2008 f250 6.4l
2004 f350 6.0l
2003 f250 6.0l -traded
2000 f250 7.3l -sold
2002 f150 Screw
1995 f150 centurion=crewcab
2004 Lincoln Aviator
  #6622
Old 06-06-2017, 09:26 PM
Jomax's Avatar
Jomax Jomax is offline
General
Member's Gallery
Default
Quote:
Originally Posted by rosspulliam View Post
Put on the new shoes finally. Next task is to get it painted up!
2002 F250 2WD lowerd 3/4 (have another hole to go in back, might use it)
Raceline 932DM Twist Dark Tint 20x9 with +12 offset, no rubbing, can go full lock and not hit the radius arm.
Toyo Proxes STII 275/55R20 front and 305/50R20 Rear
How do you like those ST2s?
__________________
2017 F-250 KR CCSB 4x4- 4400 coils, rear block removal, 20x10 novakanes, nitto 420s, king shocks, OUO traction bars, 5in Alum Driveshaft.
  #6623
Old 06-06-2017, 11:15 PM
rosspulliam's Avatar
rosspulliam rosspulliam is offline
Corporal
Member's Gallery
Default
Quote:
Originally Posted by lincolnlocker View Post
that looks good ross! why the difference in tires? why not run all the same size?
I thought 305/50R20s would rub the radius arm like a son of a gun. On the radius arm I can't fit my pinkie between the tire and the arm. I might only have a couple pieces of paper worth of clearance but it doesn't touch!
I was also worried about goosing the fender over the ****ty frontage roads here in N Texas. The stock tires would go up inside the fender and hit the liner and I thought 305s wouldn't clear the lip. The 275s fully tuck and can swing all the way up into the fender liner and miss the fender lip (confirmed on the Dallas North Tollway tonight &#128514.
On the rear the 305s would definitely collide with the fender lip if I put a big load on so it seems that my suspicions were right on. Got the air bags to fix that, they'll be going on soon.
__________________
2002 F250 CCSB
Lowered 3/4, Power Fold/Telescope '08+ Mirrors, Tymar Intake
  #6624
Old 06-06-2017, 11:26 PM
Corporal
Member's Gallery
Default
Quote:
So far so good! Just ran around town so haven't been on them over 60 mph yet. They make a little humming noise between 45-50 mph but otherwise they ride better than the hard as a rock LTX load range E tires I took off! I like these sizes because they actually exceed the weight ratings on the door sticker. Toyo does say you have to derate them 10% when using a P tire in place of an LT which drops the rear to 5800 lbs from the door sticker 6042 but everything's works out close enough for what I use the truck for.
I'm thrilled with the look. I waffled back and forth between a 0 or +12 offset wheels and +12 is 100% the way to go for me. I was worried about clearanpce on the front but it couldn't have worked out more perfectly. I can't stand it when tires stick out I don't care how small it is. Shove them bitches up in there!!
__________________
2002 F250 CCSB
  #6625
Old 06-07-2017, 12:02 AM
Corporal
Member's Gallery
Default
Took this pic running errands with the family tonight and thought it was pretty bitchin'
__________________
2002 F250 CCSB
  #6626
Old 06-07-2017, 12:28 AM
Betarocker's Avatar
Betarocker Betarocker is offline
Lieutenant
Member's Gallery
Default
Washed the truck this evening and then took the clay bar to it. CCLB sure has a lot of surface area.
__________________
2016 F350 XLT FX4 CCLB. 7" One Up Offroad/Icon/Fox, 38x13.50-18 Toyo MTs
  #6627
Old 06-07-2017, 01:26 AM
Jomax's Avatar
General
Member's Gallery
Default
Sweet, I'm going with 305 50 20 like your rear tires all the way around. The weight rating is enough IMO.
__________________
  #6628
Old 06-07-2017, 08:29 AM
Swampfox Swampfox is offline
Sergeant
Member's Gallery
Default
Quote:
Originally Posted by C2tuck View Post
Well?? Drive it yet?
Yes I put about 70 miles on it the past couple of days and it drives great. Has a more solid feel to it.
__________________
2016 Ford F-250
  #6629
Old 06-07-2017, 03:33 PM
Dmstrucks02's Avatar
Dmstrucks02 Dmstrucks02 is offline
Colonel
Member's Gallery
Default
Those look great. I was just looking at those wheels a few weeks ago for my single cab. Good info on the offset too!
Sent from my SM-G950U using Tapatalk
__________________
02 CCSB X code leafs on 33's
Texas Tuned
5" MBRP
Isspro gauges
  #6630
Old 06-07-2017, 09:54 PM
Betarocker's Avatar
Lieutenant
Member's Gallery
Default
Here's it all clean
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
