2004 F350 CC 4x4 35's. its been studded, Wicked wheel 1, 8 new MC stock injectors, SCT, re-honed cylinders, new piston rings, new glow plug harness, injector harness, tstat, fan clutch, coolant and oil temp sensors, oil and coolant bypass, all new ford gaskets seals, new oil cooler, new radiator, oil return tube, 4' straight pipe, 52 Volt ficm, stage 2 transmission,
QUESTION - FICM will drop voltage while accelerating and when you get up to speed it will stay consistent at 50-51 volts. it is getting consistent voltage to the FICM 12.5-13.5
