Go Back   PowerStrokeArmy > Power Strokes > 6.7 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 04-14-2018, 09:35 PM
CallMeColt CallMeColt is offline
Sergeant
Member's Gallery
Default SCT EGT Probe Install Questions
Going to sounds real dumb, but where should the probe be installed?
I had a local diesel tuning shop do it & I think they put it on the wrong place... they tapped in where the 90 deg bend is next the the transmission.... I would have thought it was supposed to go as close to the turbo as possible?
I did some searching on here & on Google... I couldn't find a picture for the 6.7L Powerstroke. Earlier models were tapped in right at the manifold (6.0L).
With the accelerator to the floor for 8 seconds & my EGT temperature barley broke 700 deg..... after I had been driving for a while too.
Shame on me for not doing a little research on the subject before having the work done. Should have just done it myself.... I tend to be way over the top particular on stuff like this. I don't even like it facing down because I'd be worried a branch or something could get caught & rip it out. I drive off road a lot.
I attached the picture. Sorry for bad lighting. The flanges bolted together on the top of the picture are to where the *** system would start.
Thanks for any input.
File Type: jpg 30707933_10155217149290919_9112660304088530944_n.jpg (86.8 KB, 57 views)
  #2
Old 04-14-2018, 11:28 PM
redneck1's Avatar
redneck1 redneck1 is offline
Sergeant
Member's Gallery
Default
Definitely a not a recommended placement for performance. Install a egr block plate with the egt bung welded in. It's in the valley up by your intake on the passengers side of the motor. That will do little to no good where it's at. Makes me question how legit your diesel shop is...
Sent from my iPhone using Tapatalk Pro
__________________
If you ate today, thank a farmer. If you ate in peace, thank a veteran.
  #3
Old 04-15-2018, 03:44 PM
farm boy's Avatar
farm boy farm boy is offline
Sergeant
Member's Gallery
Default
Yea that's a terrible spot for the sensor. As said above, deelete the E.G.R and install the probe in the blockoff plates as I did.
__________________
~2013 F-350 6.7L Dually 4X4
~2003 Peterbilt 330
~2002 F-250 7.3L 4X4 Flatbed
~2014 Toyota Tacoma 4X4
~2004 F-350 Shorty 6.0 2wd (SOLD)
  #4
Old 04-16-2018, 12:34 AM
95cobby's Avatar
95cobby 95cobby is offline
Sergeant
Member's Gallery
Default
Mines in the same spot as posted above.. plate in the manifold.. works great.
__________________
2019 F250 Platinum FX4 CCSB
NL CAI | NL blockoffs | 5" FLOPRO | SCT Tyrant | Fuel 20x10 Wheels | Nitto Ridge Grappler 37s | Carli Pintop 4.5" | PMF Dual Steering Stabilizer w/ Kings
2016 F250 Lariat FX4 CCSB - SOLD
  #5
Old 04-16-2018, 05:07 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
I have mine in the passenger's side up pipe
  #6
Old 04-16-2018, 06:40 AM
Sergeant
Member's Gallery
Default
Quote:
These were the type of pictures I was looking for, thank you.
  #7
Old 04-16-2018, 06:43 AM
Sergeant
Member's Gallery
Default
Thank you for all the input everyone.
I'm not happy with the shop at all. They had issues when doing my EGR ******, *** ******, & SCT Livewire TS install as well but gave me some reasonable reasons as to why it happened.
I'm going to see what they say when I tell them they did it wrong.
  #8
Old 04-16-2018, 07:44 AM
Sergeant
Member's Gallery
Default
Did you just drill & tap the block off plate hole bigger for the SCT probe, or did you get a plate that came like that? Mine has an OEM probe in it right now.
Sorry for not asking in my original quote but I don't know how to edit a post.
  #9
Old 04-16-2018, 09:40 PM
farm boy's Avatar
Sergeant
Member's Gallery
Default
The probe kit came with an adapter if I recall correctly. Or it was sent with the No limit e.g.r kit.
Either way I didn't have to source it on my own.
__________________
~2003 Peterbilt 330
  #10
Old 04-22-2018, 05:31 PM
gilgamesh gilgamesh is offline
Corporal
Member's Gallery
Default
Quote:
Is there anyplace to put it pre turbo that would read the temp of both banks combined?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
