Go Back   PowerStrokeArmy > Power Strokes > 6.4 Tech
Reply
Thread Tools Display Modes
  #1
Old 08-12-2017, 01:27 PM
strokeofgenius's Avatar
strokeofgenius strokeofgenius is offline
Sergeant
Member's Gallery
Default So this just happened
So had the truck back for two weeks after cab off for oil cooler and up pipes. Check oil this morning and.... see for yourself.
Truck is fully ******d and tuned with patri*t / spar-tan.. and no limit intake
Am I completely screwed?
08 F250
E G R ******d with elbow, D P F ******d, Rudy's up-pipes, 5 inch Flow Pro down pipe back, No limit intake, Patriot OST SOTF tunes.
__________________
08 F250 - Spar- Tuned, D-leted and Daily Driven.
  #2
Old 08-12-2017, 04:05 PM
CTC DEEZUL's Avatar
CTC DEEZUL CTC DEEZUL is online now
Colonel
Member's Gallery
Default
soooo then why is this not going back in to have the oil cooler torn down again to see if parts failure/installation failure...
__________________
Teamsters Local 444- Rolling Coal United
  #3
Old 08-12-2017, 04:07 PM
CTC DEEZUL's Avatar
Colonel
Member's Gallery
Default
and are you sure the oil has coolant in it? That sludge could just be moisture from not getting to op temp and driving around town. coolant may have never been filled properly/externally leaked??
__________________
  #4
Old 08-12-2017, 04:54 PM
Sergeant
Member's Gallery
Default
It is going back in. Ive been driving it around for two weeks with zero issues. Oil temps and coolant temps great. Never more than 6 degrees delta. Oil always looked clean. Check oil today..this is what it looks like. I am not 100% sure there is coolant in oil but mysteriously today my degas is empty and my oil is milky.so.....
08 F250
__________________
  #5
Old 08-12-2017, 07:26 PM
CTC DEEZUL's Avatar
Colonel
Member's Gallery
Default
PM me with who did the work whenever you get a chance
__________________
  #6
Old 08-12-2017, 08:33 PM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
You didn't get head studs recently did you by chance?
  #7
Old 08-13-2017, 10:11 AM
Sergeant
Member's Gallery
Default
No i did not
08 F250
__________________
  #8
Old 08-13-2017, 10:12 AM
Sergeant
Member's Gallery
Default
Was going to when I had the other work done, but did not end up paying the extra money to get them
08 F250
__________________
  #9
Old 08-13-2017, 01:58 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
Not having headstuds be the cause?
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, Garrett GT4294, Beans IDM, ARP head & main, girdle, half filled block, DI cam, ceramic coated bowls, anti-friction skirts, Haldex pump over Honey Badger Jr, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #10
Old 08-13-2017, 02:52 PM
Sergeant
Member's Gallery
Default
Idk, from what i am reading when you have a head gasket failure it gets exhaust pressure into the coolant system and pukes coolant out the overflow. Mine has not been doing that. Blow by also seemed acceptable
08 F250
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
