NEW - Bullet Proof Diesel All Billet 6.4 Water Pump
Sentinel@BPD
Mesa, AZ
Bullet Proof Diesel Provides an All Billet Solution to the Ford 6.4 Liter Power Stroke Water Pump
Mesa, AZ - November 12, 2015 - Bullet Proof Diesel, the industry leader in diesel engine reliability products, continues to improve their solution for the Ford 6.4 liter Power Stroke water pump with an all billet version. Now featuring a billet housing and mounting flange in addition to the billet impeller, this direct fit replacement to the OEM water pump is built for miles and miles of dependability.
The Bullet Proof All Billet 6.4L Water Pump continues to feature the improved billet impeller over the factory plastic one that is prone to failure. Replacing the cast housing with a stout all billet housing and mounting flange not only provides durability but also remains a direct fit replacement to the OEM version. Additionally, the new all billet 6.4L water pump utilizes a ball-roller bearing specifically designed for an automotive water pump application.
Pull steep grades with confidence knowing that cooling system issues including engine overheating due to a cracked plastic impeller are a thing of the past. Whether it’s in a heavy towing or light duty application, the reliability of the new all billet construction is exactly what every Ford 6.4L diesel owner needs.
Bullet Proof Diesel will offer the all new Bullet Proof All Billet 6.4L Water Pump priced at $399.95.
Available for purchase online at www.bulletproofdiesel.com or purchases may be made by phone by calling 1-888-967-6653.
