Go Back   PowerStrokeArmy > Non - Specific > Project Forum
Reply
Thread Tools Display Modes
  #1
Old 11-08-2020, 04:51 PM
wildbillcodyk9034's Avatar
wildbillcodyk9034 wildbillcodyk9034 is offline
Private
Member's Gallery
Default Project don’t have a name yet
So the wifey bought me a 95 F350 CCLB 4wd with no motor to upgrade my current rig and have room for both kids, new born boy and 7 year old girl.
This is current rig, 97 F250HD Efuel, 1.0 housing TS chip with canned tunes and 4 wd conversion.
I am looking for help to make it into my daily driven work truck (current rig has 535k), ya know the normal long lasting super reliable and can tow up to 25-27k combined multiple times per week. What setup would everyone recommend for this and looking for probably 400-450 hp ish.
I have the go ahead to from the wifey aka boss to get motor and rebuild/upgrade as I see fit. Thanks for the help.
Also need a name for new truck
  #2
Old 11-08-2020, 07:39 PM
Sterling6.7's Avatar
Sterling6.7 Sterling6.7 is offline
Major
Member's Gallery
Default
What is your budget? Is there any particular reason to use this truck or body style? Other than the Mrs. bought it for you of course.
__________________
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray
  #3
Old 11-08-2020, 09:21 PM
Private
Member's Gallery
Default
Had the blue truck for 13 yrs and we both live the body style. Budget, no timeframe to have it done just build and go. Would prefer to have the engine side done prior to install. Already have intercooler and 6.0 trans cooler for new truck and just collecting parts
  #4
Old 11-09-2020, 08:35 AM
Cloverleaffarm's Avatar
Cloverleaffarm Cloverleaffarm is offline
Major
Member's Gallery
Default
https://www.iratediesel.com/7-3l-pow...e-400-475rwhp/
__________________
6.7 Cummins
ARP
Air Dog
Draconian TCM
Industrial Injection
Anarchy Diesel EFI LIVE
  #5
Old 11-09-2020, 08:42 AM
dmd's Avatar
dmd dmd is offline
Lieutenant
Member's Gallery
Default
This is general, but with stock motor, upgraded hpop, 238/80(detuned, I have 160/30 but 160/80 would be better single shot tunes), 4-in exhaust, cold air intake or intake for 2001(has the tabs that break fixed), larger turbo of some sort(38r was the deal when I built mine, better choices now), a good built trans(to good valve body minimum.... Would get you a long lasting setup.
There is a lot more you can add, to everything.. but these basics would get you there.
__________________
2k, F350 SuperCruzer, 7.3L Diesel, Auto trans, 4x4, GH Tunes w/160/30s, S&B cold air intake, 4-inch turbo-back exhaust, Garrett 38r, Adrenaline HPOP, BTS Transmission w/6.0 cooler, Swamps IDM(broke, back to stock), AIC, in-tank and pre-pump mod, Heater valve mod, X-car sound panel mod
  #6
Old 11-09-2020, 08:26 PM
Private
Member's Gallery
Default
Thanks everyone, I am leaning toward the 200/100 and the 364 sxe with new hpop (adrenaline, honey badger, T500).
Has anyone done any head work? Porting and such? Is it worth it? Headers?
While the motor is out probably going to do head studs, valve springs etc. mights as well do the port polish and such if these mods are worth it but I don’t know enough about this.
  #7
Old 11-10-2020, 02:26 PM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is online now
General
Member's Gallery
Default
You will get more out of a cam at that hp level than you would with porting.
Id start with the transmission first and have it built to your end goal for truck. As in what hp and what you are usimg it for.
live life full throttle
__________________
00,f350,4x4,cc,drw. Sold... good bye ole girl. I will miss you
15,f350,4x4,cclb, not stock
  #8
Old 11-10-2020, 06:26 PM
psduser1's Avatar
psduser1 psduser1 is offline
Colonel
Member's Gallery
Default
I gotta disagree.
Even simple head port/polish will lower your observed boost pressure-meaning less airflow restriction. Bonus, if you can run a die grinder with a flapper wheel, it's easy and quick to do without paying the big money.
I'm not saying that the home job is equal to a cnc port and polish by any means, but it's pretty easy to gasket match and polish runners. That vs a 1000$ cam? No contest in my mind.
At 500 hp, it's a no brainer. At 900 hp, well that's a different animal. P/p at 500 hp lowers back pressure, boost and could very easily improve the torque and horsepower curve.
__________________
2000 f250 zf6, air, oil, fuel mods, flatbed dual dana 80
Almost stock
2001 f250 same setup as the 2000, auto trans
2002 with a couple of mods, grocerygetter
  #9
Old 11-10-2020, 10:12 PM
General
Member's Gallery
Default
Quote:
Originally Posted by psduser1 View Post
I gotta disagree.
I wasn't talking cost. I was talking hp increase. Port/polish/port match is minimal on a 7.3. Vs a cam.
Gasser world on the other hand. Fuk yes.
Since when do cams cost 1k? Holy crap
__________________
  #10
Old 01-02-2021, 11:18 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
And I'll say that head porting paired with a cam, and headers is a great power recipe. Problem is porting is expensive, as are headers. It all plays a role in the big picture.
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2018 Ram 5500 Mechanics Truck
2001Tdi Jetta 5 speed
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Designed by Military Ltd
