2010 6.4 wheel and tire question
jordysoso
Nowhere
Hey y'all, I'm looking to get a Set of 20's on my 2010 f250. Its the fx4 and not leveled yet but am open to doing it. I want a 5"+ lip on the wheel and I know it looks like I'll have to do a 20x12 wheel. Am I going to run into rubbing issues with 20x12 and 33" tire? Looking at 295-55r20 tires which give me a 11.5" wide tread. If I can run a 33x12.5" tire without rubbing I will. Just need some help from the guys that have experience as I have not.
jordysoso
Nowhere
I cam across a set of fuel Maverick 20x10 with Terra grapplers LT285/65R20 for a great deal. What would I have to do to fit them on my truck without rubbing? Need an answer fast so I know if I should move on this or not.
Here's what i know:
on an 08-10 they with with much room to spare on a 2.5" level.
on an 11+, they fit at stock height with the liners pulled back.
Will I need to change any other suspension/brake parts or just a 2.5" level?
That combo make work on a stock six four, i just havent done it so i cant tell you!
If you do level, you will need longer shocks, a drop track bar bracket(or adjustable track bar) and alignment cams (or radius arm drop brackets).
