Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #11
Old 11-15-2017, 09:24 PM
Joshf250's Avatar
Joshf250 Joshf250 is offline
Corporal
Member's Gallery
Default
Quote:
Originally Posted by 95GTSpeedDemon View Post
Put power or power and ground directly to the motor?
Sent from my LG-E980 using Tapatalk
Iíve put power and ground to the motor and it will work. Iím thinking itís the switch on the driver side panel now. If I hit the switch on the passenger side my test light will light up on plug saying Iím getting power but if I go hit the switch on the driver side I get nothing. I guess if the driver side switch is no good the circuit canít be completed. So Iíll get a new switch hopefully tomorrow and see what happens.
  #12
Old 11-16-2017, 05:43 AM
95GTSpeedDemon 95GTSpeedDemon is offline
Private
Member's Gallery
Default
Door locks and other master switch items work?
  #13
Old 11-16-2017, 05:51 AM
Joshf250's Avatar
Corporal
Member's Gallery
Default
Yes
  #14
Old 11-16-2017, 05:53 AM
Private
Member's Gallery
Default
Quote:
Originally Posted by Joshf250 View Post
Yes
Then its probably the switch. The drivers door harness ground tends to break and causes weird stuff to happen when it sources an alternative ground thru other parts.
  #15
Old 11-16-2017, 06:05 AM
Joshf250's Avatar
Corporal
Member's Gallery
Default
Where is that ground located? Iíve checked all the grounds that I can find but may be over looking something
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
Designed by Military Ltd
