custom Intake
curtis270
has anyone tried to do their own custom intake? I put a couple together for my dodge I know its not even close but I dont like the factory plastic trash on top of the engine as well as all the wasted space in the cast part. on my dodge I got rid of my maf sensor in the intake kit can you do the same with these 6.7s? Im ok with my intercooler piping as i already have the hard pipe CAC. I basically want to put together a Y manifold to replace the plastic piece on top of the motor and a 4 inch tube to the non vgt turbo. https://youtu.be/Hli09UOuL0c heres one guys way he did it.
its been done many times. you will need to retain the MAF sensor.
SickSeven780
This is the one I built for mine.
image hosting
curtis270
any chance you could send me some specs for the y deal ive got the air intake pretty much figured out?
Here is mine. First 2 are my 15 with a no limit 5" tube and the last one are my 12 with a 5 inch and homemade tube.
08Monster
What filter is that?? I like it. Looks like what they used to run on 7.3s.
Sent from my XT1585 using Tapatalk
Motostroker
For the price, S&B is pretty good as well.
I’m going to eventually get a stage one intake from mike and adapt it over though.
Sent from my iPhone using Tapatalk Pro
Its the big brother version of what they used on a 7.3.. the napa number is a 2790.
Pretty sure that’s a Donaldson filter
Yes it is a Donaldson. Not napa.
Harley-6.4
siliconeintakes.com
I personally wouldn’t use their filters but they have all the hardware you should need for your custom intake
