Go Back   PowerStrokeArmy > Power Strokes > 6.0 Tech
Reply
Thread Tools Display Modes
  #1
Old 10-16-2019, 11:00 AM
theNewb2003 theNewb2003 is offline
Private
Member's Gallery
Default My 6.0 into OBS project
Well after doing alot of searching, and coming up with very little info if any at all. I've decided to start a new thread.
I have a 1995 F250 that was a gasser, motor was bad but body and bed are straight. I purchased a wrecked 2003 f350 superduty with a 6.0 and 6spd MT. The transmission was less then two weeks old when pickup was wrecked, and motor had been bullet proofed. Yes I'm sticking ford with ford, if I wanted another dodge I would go buy another dodge...
So here are some nm picture just to get this thread started.
Sent from my SM-G892A using Tapatalk
  #2
Old 10-16-2019, 11:02 AM
Private
Member's Gallery
Default
Here are some picture of the OBS
  #3
Old 10-16-2019, 11:03 AM
Private
Member's Gallery
Default
Then there is this mess Haha
Dont forget about all this eather
  #4
Old 10-16-2019, 12:04 PM
Lt.Dan's Avatar
Lt.Dan Lt.Dan is offline
Sergeant
Member's Gallery
Default
Theres another guy doing this on PSN. Hes putting an OBS cab on an 05 frame though w/ a 6.0 in it.
__________________
1996 Cali F350 SRW CCFB, 7.3/E4OD, 2wd SAS w/ 386,000 miles, rebuilt at 352,250.
  #5
Old 10-16-2019, 12:43 PM
Private
Member's Gallery
Default
Yea I seen that, he was modding the firewall and stuff. As it is right now the only modification I have to do is finish building my motor mounts. Granted I still have a ways to go but. Transmission mountain right up no modifications to cross member or anything so.
  #6
Old 10-16-2019, 08:06 PM
Countryboy07's Avatar
Countryboy07 Countryboy07 is offline
Lieutenant
Member's Gallery
Default
Sub’d!! Can’t wait to see this finished.
__________________
03 F-250 Powerstroke
CCSB, 4x4, Lariat
Custom regulated return, zoodad mod, S&B intake
4 straight pipe to 6 tip
  #7
Old 10-16-2019, 09:03 PM
Private
Member's Gallery
Default
Ok, so as after spending most of the afternoon looking at motor mounts I accomplished nothing haha. Did get the steering box from the super duty mounted on the obs chassis. Surprisingly everything again bolted up. Did have some concern on how I was going to set up the hydro boost but with the steering box bolted up everything is good to go on that front. Will be mounting hydro boost and pedals tomorrow after finishing motor mount. More pictures tomorrow
  #8
Old 10-17-2019, 03:23 AM
Zeb Zeb is offline
Lieutenant
Member's Gallery
Default
Very nice! I’ll be watching this!
  #9
Old 10-21-2019, 02:43 PM
Private
Member's Gallery
Default
Ok update, motor is in. I ended up using the transmission mount from the 03 sd. The mount for the 1995 had the transfer case sitting to close to the driver side frame rail. I will be using the 03 gauge cluster and mounting it into the 1995 dash. There will be some modifications that I will have to do to the outer dash peice for the 1995. Will be starting on wiring tonight.... more pictures to come
  #10
Old 08-01-2020, 08:17 AM
m j m j is offline
Major
Member's Gallery
Default
any updates?
__________________
Quote:
Originally Posted by Chvyrkr
BTS transmissions have the absolute top of the line hard parts and clutches, in every single one.....every once in a while that somebody like Mike O or Charles gets a different piece, because they've broken his normal piece.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
