Go Back   PowerStrokeArmy > Power Strokes > 6.7 Tech
Reply
Thread Tools Display Modes
  #1
Old 09-15-2018, 09:24 AM
stevenkspradley's Avatar
stevenkspradley stevenkspradley is offline
Private
Member's Gallery
Default Advancetrac problems
I have a 2013 F250 6.7 diesel and it started something wierd a couple of months ago. It only happens occasionally and only when I turn my steering wheel to the right. It only happens when the vehicle is still or moving slowly and the steering wheel is turned to the right. I’ve been really busy at work and have just put this on the back burner till now. I have recently noticed what sounds like a possible wheel bearing making a noise. Could the advancetrac be a symptom of a bad wheel bearing/hub? I have roughly 137,000 miles.
  #2
Old 09-15-2018, 09:05 PM
Texan6Seven Texan6Seven is offline
Corporal
Member's Gallery
Default
I also have a ‘13 250 and mine has done this since it was new. I’ve read so many posts about the stealership never finding anything “wrong”’ and it’s a characteristic of the truck. Only happens when I make an off-camber right turn onto the street leading to our ranch. I now have 296k on the dash and have never had anything fail with the Advance Trac. I haven’t worried about it for a few years now.
__________________
2013 CCSB, 290k mi, SCT, Full diet, FloPro 4”, MPD 364.5 with piping, Carli 4.5” Commuter with Deavers, ICON trac bar, Fox steering, V Rock 20x12, 35” Toyo RT, AmpPro stereo integration w/5V signal, Alpine amps, Image Dynamics 6.5” comp all around
  #3
Old 09-25-2018, 08:03 PM
rrkroll rrkroll is offline
Private
Member's Gallery
Default
It’s the wheel bearing. Had it happen on mine as well. They are usually pretty trashed by the time the advance trac starts acting up. Jack up the tire and shake it, quickest way to know for sure
  #4
Old 11-08-2018, 01:58 PM
bgibson350 bgibson350 is offline
Private
Member's Gallery
Default
My '12 F-250 has a "service advancetrac" that popped up 2 weeks ago. It stays on all the time. Now I also have a trailer brake fault, airbag light on, tow/haul wont activate, and rear parking sensors wont turn on. I'm thinking I have a bad module but I have no idea which one. Brake and ABS lights have not come on so maybe that rules out ABS module?
  #5
Old 11-13-2018, 10:54 AM
Private
Member's Gallery
Default
This is a weird suggestion, but push your emergency brake all the way to the floor and release it. There is a connector that is attached to the E brake bracket that can get loose. Mine did a lot of the same things only it would get stuck in 3rd gear as well. If this works, detach the connector from the e brake bracket and use a zip tie to hold it together and another one to hold it up out of the way but not on the e brake bracket because the shock of the brake pedal coming up is what has a tendency to mess with the connection
  #6
Old 12-06-2018, 07:06 AM
Dsaline Dsaline is offline
Private
Member's Gallery
Default
did you ever figure this out?
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
