Go Back   PowerStrokeArmy > Power Strokes > 94-97 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 05-25-2014, 06:21 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default weird issue after e fuel install
So last weekend I finished my e fuel install, sd bowl, sd lines, hpop resovoir, etc.. with a riff raff frx. On the initial test drive, the truck would run good, until you got into it hard. It would start "skipping" or missing. I mean BAD, bad enough it chirps the tires when this happens. It would do it in any gear. My initial thought was air in the fuel system, and me never working on a manual transmission truck, made me think air in the system even more. Fast forward to a week later, truck still doing the same thing. I noticed if I take it easy in first, and second for a bit, it will not skip if I get into the throttle hard, but will do it again if i let the truck sit for a few hours. I've probably put 100 miles on the truck since the install, so the air in the fuel idea isn't looking promising anymore. Any insight? Is this normal for a manual trans truck to do with air in the fuel system? I've worked on hundreds of powerstrokes, but this is the only manua, and the only issue like this I've dealt with.
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2011 International Duraturd 4300 Mechanics truck
2001Tdi Jetta 5 speed
  #2
Old 05-25-2014, 07:08 PM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
One fuel line per head?
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, Garrett GT4294, Beans IDM, ARP head & main, girdle, half filled block, DI cam, ceramic coated bowls, anti-friction skirts, Haldex pump over Honey Badger Jr, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #3
Old 05-25-2014, 07:12 PM
Tom S's Avatar
Tom S Tom S is offline
Mod Squad
Member's Gallery
Default
Checked fuel pressure?
__________________
1996 F250 Powerstroke 4X4 AUTO
DP-Tuner F-6 chip live tuned, BTS Transmission, Garrett 38R Turbo, Swamps Injectors 150cc, electric fuel,
Banks Intercooler, Reflexxions Cowl Hood, 17 degree HPOP, 4" Stainless Magnaflow &
Aeroturbine exhaust, Aeroforce OBD Scan Gauge, Truxedo tonneau cover
Dana 60 Precision Metal Fab RSK and SD Springs
  #4
Old 05-25-2014, 07:20 PM
ghohouston's Avatar
Colonel
Member's Gallery
Default
It is set up EXACTLY like a sd, with a riff raff frx, so yes one line per head feed, one line per head return. I'm uploading videos now. No I have not verified the fuel pressure, but it wouldn't make sense to me that pressure would be low, and then somehow ruse up after a few miles. Stranger things have happened though. Videos are uploading now, and will post once uploaded.
__________________
  #5
Old 05-25-2014, 08:34 PM
ghohouston's Avatar
Colonel
Member's Gallery
Default
https://www.youtube.com/watch?v=hosg...e_gdata_player
__________________
  #6
Old 05-25-2014, 08:48 PM
ghohouston's Avatar
Colonel
Member's Gallery
Default
https://www.youtube.com/watch?v=Dtm2...e_gdata_player
__________________
  #7
Old 05-25-2014, 10:05 PM
m j m j is offline
Major
Member's Gallery
Default
time for a fuel pressure gauge.
so you changed it to a reg return or not?
__________________
Quote:
Originally Posted by Chvyrkr
BTS transmissions have the absolute top of the line hard parts and clutches, in every single one.....every once in a while that somebody like Mike O or Charles gets a different piece, because they've broken his normal piece.
  #8
Old 05-26-2014, 07:06 AM
ghohouston's Avatar
Colonel
Member's Gallery
Default
I changed it to a riff raff frx.
__________________
  #9
Old 05-26-2014, 07:08 PM
ghohouston's Avatar
Colonel
Member's Gallery
Default
Truck had a cps code, I suppose that could cause the issue. Although I find it strange it would happen at the exact same I swapped to e fuel. If/ when I ever get a day off, ill swap it and report back
__________________
  #10
Old 05-26-2014, 07:52 PM
bluedge8's Avatar
bluedge8 bluedge8 is offline
Colonel
Member's Gallery
Default
check the air intake for cracks, I have seen boots on an intake cracked almost half way around but in the bottom of the pleat so you didn't notice it, then when you stand on it, it bucks and jerks hard to figure out if you haven't seen it before. Or fuel system with a leak, sucking air?
__________________
'96 f350 cc lb 4x4, 6637, auto, 264k Pretty much stock
'03 chev 2500 crew cab duramax 395k bone stock
'02 F350 dually, Lariat, auto, banks everything, hydra on the way.
Quote:
Originally Posted by Arisley View Post
D3leted 6.0's are the best. D3lete them and replace with a Cummings.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
Designed by Military Ltd
