About to pull the trigger.. i have currently a 2001 F350 7.3 dually 2wd.. going to 4wd..love the leafsprings so sticking with the older set ups..
I have 2 axles to picking from..
Had a frame cut in half for all the brackets...found out it had a dually leveling kit all ready...2" i assume..
And have X code springs..hella high for starting
I have 5" blocks to help level it back out and poss give a little bit of rake back
Have a adjustable track bar too since this set up may give around 4" in the front
Need to get a drop thingy for the 2 pice driveshaft until i redo it with another trany and all
Who all has done this for real.. not on paper...want to know how bad the old coil buckets are to get off and any other hiccups
Just scored this new tailgate from a '16..paint is real close to matching
From you Mom's house....
