door ajar light
Mdub707
Mohawk NY
Open door, spray liberal amounts of WD40 on the latch on the door itself. Close and open door 10x. Problem fixed.
Quite common on Ferds. Had this happen on every Ford truck I've owned now.
F-250-Owner
Masontown Pa/Maputo Mozambique
okay, will try it... I also put a different door on the rear passenger side, it seems like the auto lock solenoid is stuck, it wont work with the fob, nor when I hit the lock/unlock button inside the truck.......
wetnsloppy4x
Notus, ID
It really sounds like a trip back to the body shop is in order. If they changed the door, an inoperative lock is likely on them. Unless you were having issues with it before the work, that is.
Mdub707
Mohawk NY
Ok yeah I was unaware you had a door swapped... try what I said first though, if that doesn't fix the door ajar light, then look harder at that door.
yeehaw
Dodge County,Wisconsin
i would take it back too, just cause they swapped it, worse case they say they won't do anything for you then go from there. But a good shop should look into it
Mdub707
Mohawk NY
Did I miss something? When did he say he took it to a body shop? I'm not sure he can take something back that he did himself... his post says "HE" put a new door on... or did I miss something here?
wetnsloppy4x
Notus, ID
just picked my truck up fromt the body shop and the door ajar light will not go out.... kind of annoying. any ideas what could be going on?
:poke:
