08+ Upliftter switch install with harness
ZombieHNTR
Tracy, CA
Has anyone done this. I picked up the upfitter switch to find out another site gave me some false info on the extra plugs behind my dash so I am going to order the wiring harness to complete this project. Has anyone else done this?
Suggestions?
MEAT
Baltimore, MD
I am looking to do the same thing, my truck came with the change tray next to the trailer brake controller. I have read on various other forums that all I needed to do was buy the switches, and all the wiring and harnesses to make them work were already in the dash. I am judging from your post that this information is not correct? Hope someone can give some more info.
mike61
Santa Fe, TX
i did this on an 06 wiring plugs in behind the glove box and have to feed to the cubby spot it doesnt take very long just take your time and also did the high idle mod using the last small amp or voltage switch on the far right
taterthedog
Canada
Dustin has the instructions stickied in the 6.4 tech section of the Library. First one in there. :toast:
Beans71086
North East, MD / Clearville, PA
