6.4 Turbo smart BOV
Miamisixfour
Miami
Hello,
currently wiring up a Turbosmart BOV to my 6.4 and can not figure out where to get the TPS signal from .
If anyone can help me out that would be greatly appreciated.
Thanks x100 in advance
pog
psa
It’s one of the wires that lead into the pedal. I forget which one it is but look by your throttle pedal
akf250
Benefits
What are the benefits of a electronic wastegate over a standard spring wastegate?
Lipka101
Maryland
I don't think there is an electronic wastegate available. What he has here is a blowoff valve, which goes on the intake side to dump off extra boost in situation where you have let out of the throttle quickly. A wastegate is on exhaust side to reduce exhaust back pressure and prevent turbo over speeding.
Sent from my iPhone using Tapatalk Pro
akf250
Blow off vs. Wastegate
Ah ha gotcha, thank you
