Go Back   PowerStrokeArmy > Power Strokes > 6.0 Aftermarket
Reply
Thread Tools Display Modes
  #1
Old 09-19-2017, 12:42 PM
Jshields Jshields is offline
Private
Member's Gallery
Default Best EGR ****** for 2006 6.0
I've looked with the search and found some old stuff but I'm still clueless. I've been looking at all the EGR ******s and want to find out what's worked the best for everyone. I'm new to Diesels so I'm still learning so bare with me.
  #2
Old 09-19-2017, 01:39 PM
03_PSD's Avatar
03_PSD 03_PSD is offline
Lieutenant
Member's Gallery
Default
I like the welded egr which leaves the egr in place but not functional, but I have to pass a visual inspection here.
__________________
2004 F250 4x4 Harley
  #3
Old 09-19-2017, 01:46 PM
Private
Member's Gallery
Default
I've seen people do tha. I don't have to worry about visual or any kind if inspection. I've looked at the Sinister, Rudys and IPR ******s.
  #4
Old 09-19-2017, 03:29 PM
sideactiondiesel's Avatar
sideactiondiesel sideactiondiesel is offline
Lieutenant
Member's Gallery
Default
In stock ready to ship.
http://www.sideactiondiesel.com/60-_c_95.html
__________________
Brenton Lindenberg
Side Action Diesel Performance
1-815-703-6652
6.4 FBD blocks
6.4 triple turbo kits
6.4 dual fuel kits
6.7 replacement and upgraded turbo's
Along with Allison,Dodge, Ford Converters and full transmission builds
Quality products
" The bitterness of poor quality remains long after the sweetness of low price is forgotten"
  #5
Old 09-19-2017, 06:54 PM
Private
Member's Gallery
Default
Are the Rudys Diesel kits any good?
  #6
Old 09-19-2017, 09:47 PM
powerlifter405's Avatar
powerlifter405 powerlifter405 is offline
Major
Member's Gallery
Default
Quote:
Exactly and it makes resale so much easier. AND if you travel through a region that does road side emissions inspections that is one less hassle to deal w/.
I prefer to be on the DL
__________________
05 original factory head gaskets and TTY bolts until 302k Did ARP 1 bolt at at time@ 250ftlbs, no egr Redhead steering gear KC 63.5mm... factory exhaust w/ no meow/factory intake all factory stuff, rancho 9K's adj, PM w/ questions
  #7
Old 09-19-2017, 09:54 PM
LovinPSDs LovinPSDs is offline
Major
Member's Gallery
Default
Would you just weld the stocker or go the route of "upgraded" to not worry about cracking from the heat cycles it's seen thus far.
On edit: I'm thinking this is a dumb comment... you reroute the coolant as well correct?
__________________
2005 - 6.0 - Mods in progress
Lookin for a cheap TDI
  #8
Old 09-20-2017, 05:31 AM
Towerguy Towerguy is offline
Sergeant
Member's Gallery
Default
Negative, with a welded cooler you are just blocking the flow of exhaust through the cooler. Water flow is unchanged. That's actually a point in favor of welding the cooler since you maintain OEM fitment. Sone people have trouble with leaks on aftermarket kits that sometimes don't fit as well as stock parts. Also, it looks like you have a 2006 so you have a scoop in the up-pipe that hinders exhaust flow. You will want to cut that out or get a pipe with it already removed to remove a giant flow restriction along with helping spool the turbo.
__________________
David Frost
2005 F250 Harley CCSB
  #9
Old 09-20-2017, 06:33 AM
Private
Member's Gallery
Default
Quote:
Does anyone have a picture of this scoop. I'm not sure what your referring to
  #10
Old 09-20-2017, 01:06 PM
Private
Member's Gallery
Default
So if I weld freeze plugs in both ends of the EGR, remove the scoop in the up pipe do I need to put a block off plate in the up pipe too
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
