Budget Sump
BDP Sales
Murfreesboro, TN
We came out with a budget sump. It is $120 shipped to your door. No frills just a plain sump with no hole saw. Includes sticker and instructions. We are offering it to the forums only at this point. You must call 615-563-7800 ext 22 to order. Please leave your name and number if you miss me. Thanks!
CSIPSD
Bend, OR
Not a fan of sumps, but if I was going to do one this is how I would do it.
The fancy colors and such are all gone after the first winter anyway!
Nice work!
Diezel Dawg
Cheney, WA
How would you not have to drop the tank to put it on?
Use a hole saw after draining the tank. Cut the hole, and install. Very easy. Get the sump for any higher hp application and aftermarket fuel system. I have had no issues with my sump, even tho it isn't Beans. My furl system is happy with it and I do not worry about leaks. If it leaks, it is installer error
Sent from my Nexus 5 using Tapatalk
Diezel Dawg
Cheney, WA
You will need aftermarket lines I do believe. I would install the sump when u do a full fuel system
BDP Sales
Murfreesboro, TN
All you need is an adapter. It's just a pain to do, but I don't see why it would be a bad idea. Should help the fuel pump last a little longer.
