Stroker04
I have a NEW never used warren dual high pressure oil pump setup. Comes with all the high pressure lines, fittings, bracket, pump, and serpentine belt. You will need a feed line for the pump coming from the oil pan. I have another oil pan as well with a fitting welded in the pan. I will have pictures up shortly. Asking 700$ plus shipping I am located in Gettysburg, PA.
