OBS white smoke issue
08Monster
I have a customer here that brought in a 1997 F250, crew cab shortbox (rare truck), the truck hasn't ran since 2005. I got it running, it pours an insane amount of white smoke. Once it's warm it will idle clear, but won't rev past 1800-2000 and pour a crazy amount of smoke once you get that high in the RPMs. Any thoughts?
I drained the tanks and got some new fuel in there, changed the fuel filter.
Sent from my Moto Z (2) using Tapatalk
co04cobra
WV
Check turbo. If you go under VCs pull compression. Then continue with injector and/or Oring failure.
08Monster
What do you mean by check turbo? Just shaft play? That's kind of what I think the problem is in the upper rpm but when coldish she smokes white that would block out intersections. Runs smooth as can be though
