Go Back   PowerStrokeArmy > Power Strokes > 7.3 Tech
Reply
Thread Tools Display Modes
  #1
Old 06-13-2018, 07:52 AM
08Monster's Avatar
08Monster 08Monster is offline
Major
Member's Gallery
Default OBS white smoke issue
I have a customer here that brought in a 1997 F250, crew cab shortbox (rare truck), the truck hasn't ran since 2005. I got it running, it pours an insane amount of white smoke. Once it's warm it will idle clear, but won't rev past 1800-2000 and pour a crazy amount of smoke once you get that high in the RPMs. Any thoughts?
I drained the tanks and got some new fuel in there, changed the fuel filter.
Sent from my Moto Z (2) using Tapatalk
  #2
Old 06-13-2018, 07:55 AM
Magnum PD's Avatar
Magnum PD Magnum PD is offline
General
Member's Gallery
Default
Need to see what the high pressure oil is also.
__________________
96 F-350 RC 4x4 Hypermax Rods, PIS 300/200s G head tunes, Garrett GT4294, Beans IDM, ARP head & main, girdle, half filled block, DI cam, ceramic coated bowls, anti-friction skirts, Haldex pump over Honey Badger Jr, Diesel site High volume lpop, Billet intake Plenums, Dual SD pumps, Fluidampner, beehive springs, cosmetic head gaskets, Inconel valves, hardend guides, Ported and polished heads by me, home made RR fuel, 5 speed tranny, with SB 3600 DxD. Snow water meth.
  #3
Old 06-13-2018, 08:14 AM
08Monster's Avatar
Major
Member's Gallery
Default
Quote:
Builds ICP good, holds 2k+ no prob. What info are you looking for in particular
  #4
Old 06-13-2018, 09:15 AM
sootie's Avatar
sootie sootie is offline
General
Member's Gallery
Default
what does the smoke smell like
  #5
Old 06-13-2018, 11:26 AM
08Monster's Avatar
Major
Member's Gallery
Default
Quote:
Raw fuel
  #6
Old 06-13-2018, 06:34 PM
ghohouston's Avatar
ghohouston ghohouston is offline
Colonel
Member's Gallery
Default
Blowby? Ect reading verified accurate?
__________________
1997 F350 SRW CCLB 4x4 ZF5 7.3
2011 International Duraturd 4300 Mechanics truck
2001Tdi Jetta 5 speed
  #7
Old 06-13-2018, 08:09 PM
co04cobra's Avatar
co04cobra co04cobra is offline
Sponsor
Member's Gallery
Default
Check turbo. If you go under VCs pull compression. Then continue with injector and/or Oring failure.
__________________
00 cc/sb zf6 F250- Some stuff done always more to do-Fuel 300/200s Air-Garrett 68/94-Oil SRP 1-Airdog to Fuellab
97 cc/sb- zf-5- Work in progress. PMF rsk w/ SD axles. 66 turbo, E fuel, 230/100s. SB DD clutch.
08 cc/sb - Elite bottom end - 2 fuelers, 59vgt/78atmo, Midwest 100% nozzles and coated heads etc....
www.teddavisautos.com
Many parts available for super duty trucks PM me.
  #8
Old 06-13-2018, 08:42 PM
08Monster's Avatar
Major
Member's Gallery
Default
Quote:
What do you mean by check turbo? Just shaft play? That's kind of what I think the problem is in the upper rpm but when coldish she smokes white that would block out intersections. Runs smooth as can be though
  #9
Old 06-13-2018, 09:57 PM
co04cobra's Avatar
Sponsor
Member's Gallery
Default
Shaft play and take the DP loose to check for oil.
__________________
  #10
Old 06-16-2018, 06:35 AM
mandkole's Avatar
mandkole mandkole is offline
Major
Member's Gallery
Default
I'd throw a new fuel pump on and service everything .. it could be dead.
__________________
2000 F250 CCSB GT4294R, 250/100s, Dahl/Fuelab, BTS, PHP tuning, stock 17* pump
1994 F250 SCLB
(sold)
1997 F250 CCSB 2wd (sold)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
