Go Back   PowerStrokeArmy > Power Strokes > 6.4 Tech
Reply
Thread Tools Display Modes
  #1
Old 02-10-2019, 09:17 PM
kleake kleake is offline
Sergeant
Member's Gallery
Default Trailer charge line draining trailer battery while engine off
Anyone ever leave your trailer plugged into the truck while it's not running and have it drain your trailer battery? Once the truck starts it's charging fine, but shut it off and there is about a 1amp drain on that line. Pulled the relay and unplugged the trailer, test light on positive, probe on the relay terminal to the trailer plug and it lights my test light dim. I've heard of water being in the trailer plug and I think I sealed that up a few years ago. Not sure if it's in the plug or somewhere in the wiring. I only have the factory plug at the bumper, nothing added in the bed or anywhere else.
  #2
Old 02-10-2019, 09:51 PM
ithumpwheniwalk ithumpwheniwalk is offline
Sergeant
Member's Gallery
Default
I've towed 5th wheels and bumper pulls for years and never leave em plugged in once the truck is parked. At least not for more than a few hours, but it has always been my experience it will kill your battery if left over the weekend etc...
__________________
e99 F350 ccsb 7.3l 6spd, 160cc's from Cass, d66, tunes from BTS, Adrenaline, 6637, and a few other goodies I've forgotten...
  #3
Old 02-10-2019, 10:00 PM
Sergeant
Member's Gallery
Default
Quote:
It's not killing the battery on the truck, which is normally what it will kill due to the trailer drain. The truck has a relay to shut off the charge line to the trailer when you turn the key off, what is happening is the truck is then killing the trailer battery while sitting due to some draw on that charge line on the truck side. My utility trailer can sit for weeks by itself and the battery is fine, but plug it into the truck overnight and it's at 0V. The truck starts right up and starts charging the trailer again. Some sort of parasitic draw in the truck wiring.
  #4
Old 02-11-2019, 05:55 AM
lincolnlocker's Avatar
lincolnlocker lincolnlocker is online now
General
Member's Gallery
Default
Quote:
If there is any moisture in any of the plugs that lead to the trailer it may have a cross connection through the moisture if its enough. Id take apart the pig tails from the main wire harness in the rear of the truck to the trailer and make sure they are clean and dry. I know you dont deal with salt or sodium chloride like we do i the north but that chit in liquid form can wreak havoc on electrical connections and components.
live life full throttle
__________________
00,f350,4x4,cc,drw, under the knife
01 rclb zf6,4x4,srw,ts tunes,bfaf,4"exhaust, 3800lb dd clutch
12,f350,4x4,cclb,srw, rudys/punch it d3lete tunes, donaldson bfaf.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin®
Designed by Military Ltd
