Show & Go/Going to Try this Out combo Build
Jonnydime
Cool deal, I’m in Muskegon. You ever make it up this way anymore? Crazy seeing pics of work being done outside we have over a foot of snow on the ground
I usually make it up that way a few times a year. It was 80 degrees here today.
Jonnydime
Getting close.
Jonnydime
Had it running today but still have some small things to finish up. It is definitely going to need a muffler.
Jonnydime
It's big and silver and round. And I bet it gets hot.
Hopefully it doesn't get that hot. I'm going to try to reuse it as an intermediate pipe for the compounds when I build them.
Black AOD
Ohio
What's your plan for an atmo when you do compounds?
Jonnydime
I haven’t planned that far ahead. I was thinking f3 pro charger but I haven’t made my mind up yet. I might use the 82 I already have as well.
Jonnydime
Thoughts on twin 6466's as low pressures? The big boy precisions are so expensive to the point that I could buy two 6466's for the price of one 88+mm single.
Jonnydime
Had to get creative with the low pressure system. I didn’t want the water separator as close to the ground as it was on the red truck so I relocated it to the bed.
Lipka101
Maryland
Interesting, there was no way to move it up like the other filter or is the Seperator that much bigger?
Sent from my iPhone using Tapatalk Pro
Jonnydime
After some consultation I am moving the water separator back to the suction side of the pump on the frame rail. Turns out Dahl doesn’t recommend pumping thru their unit.
Jonnydime
Setup number 3. Hangs about 2” below the bottom of the bedside which is about 4” higher than it was on the red truck.
