Turning on backup camera while driving?
Rustedcutlery
Is it possible? I think it would be handy when pulling a trailer to see if anything has moved.
188slo50
Factory setup i would say no do to it being illegal in most states to watch a video while driving (if you know what the wiring is than you can change it). Aftermarket you can do what ever you want just hook your video wire to a common wire and not the e-brake.
NY_Mott
The Real "OC" NY
I am interested in this also... I would like to disable all the moving restrictions the system has including the alley lights...
BIG JUICE
Valrico FLA
They make a lock pick for sync 3 yet?
I was going to buy one for my 15 but I'll try to find it in forscan first
NY_Mott
The Real "OC" NY
Yes they are on the mirrors, I guess because they are just ok and not great you might also call them curtisy lights.. I would say mine shine out about 10-15 feet or so from the truck.
They can be turned on under 5mph and shut off over 5mph.
JRLott
TX
Thanks, NY. That’s what I was guessing, but thought there might be something I was missing.
Quigs4u
Any word on this? Can it be done......yet
Tricon
I did this in my Tundra. You just have to find the reverse signal wire in the harness and tap it to a upfitter switch.
If someone has the complete wiring schematic I can sift through it to try and find the right one.
