Coolant leak from passenger side of motor
15Platinum67
Hey guys I noticed a constant coolant leak on the passenger side of the motor while it’s running it’s coming from the rear passenger side of the motor . Took a picture here see if you guys have any ideas I would really appreciate the help. The truck is studded and ******d.
Lipka101
Maryland
Probably from the short piece of hose between egr ****** and oil cooler
Sent from my iPhone using Tapatalk Pro
15Platinum67
I looks to be leaking from where the ****** J pipe connects into the manifold any ever seen this before ? Maybe O rings aren’t good anymore?
powerlifter405
Butt Town
Had that happen on mine after about 6 months of doing the dee-lete.
Noticed a drip again but I'm seeing some build up of deposits around the heater control valve. Its -1 so I'll deal w/ it for now but when it warms up some I'll pressure test the system.
But I'd venture it is one of those two locations that could be causing it.
If you have a way to pressure test that would be a simple tool to figure out your issue.
