MrOneEyedBoh
- Joined
- Feb 24, 2013
- Messages
- 799
- Reaction score
- 0
So here is where Im at, I have an 06 with 190/75s from MPD. Also I recently had all the updates done in the HPO system. I havent been able to run a full hard WOT run, but I got it up there and seen 4.2v max on ICP and 95% on IPR. Im running Gearheads SRL+ tune. I was under the impression that I wouldnt need a larger HPOP or more oil with 190/75s.
FP is low around 45,) Im only at about 3/4 throttle ) and it can go lower but I havent pushed it past that. Im waiting for the weather to break to get the fuel system in ( I do have a RR installed as well ). Could there still be more oil left on the table since Im not at WOT? I thought ICP would reach its max around 3/4 throttle?
The other thing that has me thinking somethings up is the 95% IPR on all heavy runs. Shouldn't that max out at around 80% or so? IPR is 25% at idle.
What would be next to get the ICP up? HPODS? Thumper? :fustrate:
