Another axle swap thread
KPSquared
Wetaskiwin, AB, CAN
I've done some research and I know how easy an 05 axle swap into my 01 is. I have access to a complete set on the frame.
However... I also have a line on an 08 set on a frame and I want to run a 4" lift.
What's different about 08 and up? If I'm running a lift with new radius arms etc, I'm guessing I need less stock components for the swap.
Links or info appreciated.
uncool
California
Sway bar mount at the axle are different.
Most of the lift kits I have seen, 05 - 07 use a longer link for the sway bar.
08 and up tend to drop the sway bar at the frame.
Other than that not much changes.
I say get the least expensive front end and go from there.
I used an 06 front end on mine with 4.5" Icon coils. I think the brake lines have a better routing on the 05 - 07 for the older trucks.
scparrish
DFW Texas
Use the 05-07 the sway bar will be much easier to deal with. I am still trying to find a sway bar that will work on my 08 axle swap.
KPSquared
Wetaskiwin, AB, CAN
Well, I'm committed now. Rolling chassis with a box on it just got dropped off in my yard. $700 Canadian Pesos delivered. 2010 with 100,000 miles on it.
Now to figure out who's lift to use.
